![]() Join Date: May 2013
Anyone on this forum use the Mastertech 3100 for diagnostics on the Z?
![]() Join Date: Oct 2004
Mastertech 3100 is essentially a Tech1 for the "general market" - I believe that most of the cartridges for the Tech1 & 1A will interchange and of course for the "general market" it included some optional cards. I don't have one but have seen it used in shops but have no "hands on"!!
#3 | |
#4 | |
If you didn't receive a user guide: http://www.evnut.com/docs/rav_docs/S...torsManual.pdf What cartridges were included? List them and it should be easily sorted. |
#5 | |
Keep you eye open on Ebay for adapters and other cartridges that go with the system.
I am not saying you need all these but here is what is available for your search on Ebay or craigslist. It will also serve as a gauge to how complete your kit is. Usually I find out what part I need when the book tells me to use a certain adapter[/SIZE][/FONT] Cat 5 silver Cable with RS232 interface (No part number) This allows inerface with printers and computers Power point extender both fused leads to battery (No part number) RJ45 Phone Plug 5 Red Cable with voltmeter test lead (No Part number) Cat 5 cable Silver that loops into itself (No Part number) Bosch ABS Adapter PN TA00022 GM Pin E Adapter PN TA02149 GM 16/12 Pin non-OBDII DLC Adapter PN 3000053 Tech 1 Test adapter with A&B Probe ports. No part number 14Pin DLC Self test adapter PN TA01142 Tech 1 14/12 PIN Vim Adapter PN 3000086 T-100 12-16 PIN Adapter 3000055 Tech 1/1AnVehicle Interface Module (VIM) PN 3000078 VIM 16/24 PIN DLC Adapter cable PN 3000081 RWAL/4WAL Adapter TA 02659A GM 12//14 PIN ALDL Adapter TA01140 14 Pin DLC Cable TA 01150 Tech 1 OBD II Vehicle Interface Module (VIM) PN 3000091 Cartridges GM 88-92 Body Systems PN TK03040 GM 81-92 ECM PN TK02050 Chevrolet 90-92 EEPROM Data Version 2.0 PN TK06032A GM 88-92 Brake TK03030 Hydromatic transmission 88-91 TK03590 I highly suggest seeking the manuals which exist for each of modules/cartiges listed above (They are in a small loose leaf format in very small binders. They are an invaluable tool that provides step by step instructions on how to use the Tech-1A and its individual cartridges and adapters and cable.
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 11-11-2013 at 01:59 PM. |
With what you have - if you've got the proper ALDL cables you can do the powertrain only for the years and models listed for the cartridges. There's no assurance that ALL of the Tech1 cartridges will work with the device. Don't assume it all will!
#8 | |
Does the 3100 work well for you on your car? |
Thanks WV. I have quite a few cable with adapters for all kinds of cars especially the GM stuff. This tester came from a Chevy mechanic who is getting out of the biz. Do you know what the cartridge "Chevrolet EPROM service" is for?
#10 | |
