10-20-2013 | #81 |
Re: TOP END REFINISHING
I can machine the coolant pipes as you have them marked but NOT the air horn. I have tried one with bad results. The coolant pipes would look great with my engraving done with my design and painted all black including the Bowie.
10-20-2013 | #82 | |
10-21-2013 | #83 | |
I would know 'NOTHING... NOTHING' about mods
10-21-2013 | #84 |
10-21-2013 | #85 |
Starter. Another BEAR. Especially when you try to TIGHTEN, and not LOOSEN one of the bolts - dumbace
Double box wrench. Couldn't do diddly with torque wrench / 1/2" - 3/8" drive adapter / 8" ext / u-joint / 13mm - probably didn't have enough pieces in the sequence . Separation into the drink for a brush-off, then set to dry + Shop-Vac excess solvent.
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 10-22-2013 at 10:19 AM. |
10-21-2013 | #86 |
Deleted thumbnails.
10-21-2013 | #87 |
Yep, I agree with Dyno. I think glycol anti freeze + heat will eat away at the paint over time. Its best to have the hoses clamped on to metal instead of paint in my opinion. You could try it and see but no warranties. They sure are purdy though.
10-21-2013 | #88 |
I agree with Franke the pipes should not be painted where the hose clamps go.....Powder Coat OK but not paint. Then I would use a thin coat of Permatex inside the hose before I slip them on the pipes. Clamps as close to the raised ring on the end of the pipe as possible. Leave the paint on the portion of pipe up to where the clamp would be on the pipe.
10-21-2013 | #89 |
Now do not move that AC compressor around too much without tying down the hose ends going into the Evaporator. You do NOT want any bending on those pipes going into the Evaporator or they could break like mine did
Oh.....on the painted pipes....I mean to say I would not have the hose clamp over a painted pipe.....Leave the paint on the portion of pipe up to where the clamp would be on the pipe. You can see with the SAMCO hose clamps being right next to the raised portion of the pipe. Now on another point.....SAMCO Silicon hoses are more elastic and flexible with temperature than rubber hoses and I have had SAMCO hoses slip on me especially with Permatex on the pipe/inside the hose. I still use a bit of Permatex but am careful where I place the Hose Clamp. Last edited by Dynomite; 10-21-2013 at 09:44 PM. |
10-21-2013 | #90 | |
I've always slipped hoses back on with silicone fluid, or Trans-X ... (story about Trans-X - I had a 60k '89 T-Bird auto, bought for a song in '93, with Ford TSB tech service bulletin for the auto valve body seals, that made it skip second gear (I didn't know about it). AAMCO said $1k to rebuild. A FORD shop tech told me the known issue, said (quietly) put in a bottle of Trans-X. I did. In 4 - 5 shift cycles, first drive, it shifted PERFECT. Trans-X does wonders on latex.......... )
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] |
