Old 10-14-2013   #1
Schrade
Default Fuel pump test terminal?
Where is it?
I need to do pressure test with a jumped 12V source, since everything is dis-connected here...
'UNDERHOOD' - narrows it down a little... The first schematic already shows it near the drivers side somewhere. Anybody got a snappics here?
Old 10-15-2013   #2
Default Re: Fuel pump test terminal?
Fuel pump test connector TIPS
Old 10-15-2013   #3
Schrade
Thanks there Cliff...
Marc says 43 is good enough; FSM says 48 is minimum.
Old 10-15-2013   #4
If I had my choice of going with Marc or FSM.......well......that is a No Brainer for me....Marc ALL the time
Old 10-15-2013   #5
Schrade
Does this look like an OEM test connector?
Old 10-15-2013   #6
92whiteZ
90% sure that is it. but there are others that know more than I.
92whiteZ is offline   Reply With Quote
Old 10-15-2013   #7
Schrade
Thanks!
Sure wish the 'others' would post up some more in the 'diags' thread tho'...
Old 10-15-2013   #8
Franke
Schrade, on page 6e3-a-6 in FSM it says" 490red Fuel pump test connector located near battery. Must be the one you found. Goes to terminal 3 of pri fuel pump relay.
Old 10-15-2013   #9
Franke
Concerning the fuel question. I want to make sure I understand what is being said here. The FSM indicates ign on - engine off pressure to be 48-55 PSI. Then ign on - engine idling fuel pressure to be 3-10 PSI less indicating regulator control is functioning. FSM then indicates approx. 43 PSI in idle. Is that what Marc is indicating? Static versus dynamic pressures.
Old 10-16-2013   #10
Schrade
Not sure there Franke; I had 44 static (NO leakdown) (which Marc says is sufficient (43) ). Kinda' bothers me, but he's the doc on this mill.
Dynamic idle with vacuum was 40 (I haven't seen his spec for THAT). I saw in FSM that spec drop dynamic is 3 - 10, so I'm good there. Need his feedback on it...
I'll test again when everything is dry-fit - yep all together dry, and dis-assemble AGAIN - familiarity, sequence, KNOWLEDGE
Thanks again there...................
