04-18-2007 | #1 |
is the belt tensioner same on z as standard vette??
hi all, i think i need to replace the belt tesioner on the Z (its chattering a little) and the only one i can find(ecklers) doesn't specify for Z or not, just says 88-91 and the guy at ecklers has no idea. does anyone know if its the same and/or where i can get one.........B.G. is getting close and i want it in tip-top for the trip! thanks
04-18-2007 | #2 |
Re: is the belt tensioner same on z as standard vette??
i changed mine last year...its not the same as the l98/lt1,but it was still available from gm last year...dont remember the part number.....
bj |
04-18-2007 | #3 | |
Uly Past OWNER 90 ZR-1 #0120 Red/Saddle UT Plate: EZR1DER |
04-18-2007 | #4 |
thanks for the response guys i just put one on......GM $135.00......AUTOZONE $11.85
04-19-2007 | #5 | |
