Old 04-17-2007   #1
Artic93
Artic93's Avatar
Default Steering drifts
Running new Sumitumo's on factory wheels, steering seems to drift at 70 +. Had the suspension on the soft mode and it just didn't feel like it was "on rails" like it should feel...is this just a perception or is there steering parts on a 13 yr old 14k mile car that need replaced?
jason
Artic93 is offline   Reply With Quote
Old 04-17-2007   #2
Jeffvette
Default Re: Steering drifts
Was it more of a "floating" feeling? Or a wandering feeling?
Old 04-17-2007   #3
I've experienced some less than spectacular stability and have found one issue to be most prominent......piss poor alignment from supposedly professional shops. I also suggest slight front toe-in. The slightest toe-out causes steering wander & rut tracking. Don't over look the rear toe alignment. Check tie rod ends, front & rear.
Another stability problem comes from dry-rotted/worn rubber suspension parts. For stability problems, look at the rear links (dog bones) both upper & lower.
Replace rubber with polyurethane wherever you can. In applications like a-frames, they tend to squeak, but I still prefer the poly over rubber.
Good hunting.
[I][COLOR=#ff0000][B]JERRYS LT5 GASKETS & PARTS[/B][/COLOR][/I]
[URL="http://www.jerrysgaskets.com"][U][COLOR=blue]http://www.jerrysgaskets.com[/COLOR][/U][/URL]
1994 [B][I]ZR-1[/I][/B], Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc.
Old 04-18-2007   #4
Artic93
Artic93's Avatar
alignment sounds possible due to just having new tires installed, but I'll pass along your idea's of other things to my shop.
Jeffvette , it seems like floating a bit @70 mph and one inch movement in the wheel did not give (what I would think) to be the razor like handling I would expect.
I admit, I don't have more than 400 miles in the seat experience yet.
Old 04-18-2007   #5
Jeffvette
Check the things Jerry mentioned as well. If you are getting float, you are going to need to either revalve your shocks or just replace them.
Bushings will make a huge improvement in the handling of any vehicle.
Old 04-18-2007   #6
zr-1assassin
zr-1assassin's Avatar
jason
HEY JASON.....can i assume you have the five stars on?? i do remember a little promise of some pics
zr-1assassin is offline   Reply With Quote
Old 04-18-2007   #7
Artic93
Artic93's Avatar
LOL ! nope not on yet, getting the tires mounted tomarrow ,if it works out with my schedule. Are you going to be passing thru Columbia on I-70 when you head to BG ??
jason
Old 04-21-2007   #8
zr-1assassin
jason
yes actualy i think we are heading east on 70,are you going down too? i'm going wed afternoon if everything goes as it should.
Old 04-22-2007   #9
This is proly redundant in light of Jeff's and Jerry's comments.....but I would add few things to the list of suspects. The rack mount bushings and the tie rod ends and that u-joint coupler on the steering shaft. I listed those in the order that I think that they would fail or become worn.
Just a thought.
