Where is it in the FSM? I thought it was 8D, but guess I thought wrong here...
Anyone know it offhand here? |
![]() Join Date: May 2013
Schrade,
Try 0B-4 in front of manual. By the way did you get the cure on that hesitation? |
Thanks there Franke!
No; I'm believing that the 'off-idle sag' issue, is DIRECTLY causing the Cruise issue as well - a 2mph swing in speed - any speed, when cruise is engaged. I'm attacking the 'sag' from a different angle, until I get DataMaster navigation down (which may show some Voltage swing on some circuit). CC diags flow chart for 'loping' cruise (NOT flow chart for total Cruise failure), DOES include a vac leak in CC vac servo lines. Working on vac routing now.......... I may have a vac leak somewhere, causing both CC issue, AND 'off idle sag'. Is Cruise vac supply, and MAP vac supply integrated??? Idle quality is perfect however - no loping. ![]() AND, it may be related to the A4 4L60e tranny Controller Module, or CM wiring ........................ Thinking hard on this now with my 'CPU', and it's smokin' hot - you can tell by the dual ear exhaust ![]() ![]() Last edited by Schrade; 08-31-2013 at 02:14 AM. |
![]() Join Date: Jan 2009
No need to go to the FSM for this info. It is conveniently located in the owner's manual on page 86. I put a yellow sticky on that page. It's handy knowing it's right there in the glove compartment cause there's no frigging way I'll ever remember the sequence for more than two days.
![]() To see what that page looks like look at post 20 on this thread: http://www.zr1.net/forum/showthread....ighlight=reset
#6 | |
But alas, I think every interior 'extra' was still in my Z when I bought it, the OM was NOT ![]() |
#7 | |
Some good "quick" info in there when you on the road. (fuses etc). Carrying the FSM is fairly bulky and yet..... With a smart phone and access the this forum..... who needs it ![]() Yet another byproduct of technology changes. Instant access to the masses for help. Cool beans.
I know you have done quite a bit of troubleshooting to cure the hesitation. Especially from the fuel point of view. I was thinking about what is required to have a smooth transition from idle to off idle. Fuel and air in the right amounts at the right time. Have you checked the throttle body for fouling and or air leaks?
#9 | |
#10 | |
![]() Join Date: Aug 2010
