Old 08-26-2013   #1
hottrodcrazy
Default Possible Leak - Engine Smoking
Please give you advice on a problem I am having. I just bought a 1991 ZR1 with 6000 miles. I haven't really driven it yet, but when I start it up and it gets warm enough it starts smoking below plugs 4 & 6. I can't see where it's coming from and don't find any leaks on the ground below the car. After a few minutes it burns off and stops smoking, but I have started it several times and it continues to do this. I'm guessing it's probably a small oil leak, but again, I can't find actual evidence or the location of a leak.
Does anyone have any ideas? Thanks.
hottrodcrazy is offline   Reply With Quote
Old 08-26-2013   #2
Default Re: Possible Leak - Engine Smoking
Anything out the back? Oil or coolant? May be header stud leaking oil.
Old 08-26-2013   #3
hottrodcrazy
There is possibly a little smoke coming out the back. I thought possibly that could just be exhaust. I'm not sure if it's oil or coolant, it doesn't smell like oil and I'm not exactly sure what coolant would smell like.
Sorry, I don't have better answers to the question. I appreciate the help, I just know that I'm getting some smoke, can't tell what type of smoke it is and as I said previously, can't see evidence of where it's coming from. Thanks again.
Old 08-26-2013   #4
Franke
The ZR-1 Net Registry has info on oil leaks for the LT5 Engine. I think Xfire may be spot on here.
An excerpt from the tech articles "If you have a leak coming from the center of the engine, seemingly from the exhaust manifold, you might be correct. On some engines, the center studs for the exhaust manifolds are drilled into or nearly into an oil passage. Eventually, the oil works it's way through the stud's threads, causing a leak. Removal of the stud and the application of a sealer usually resolves this problem."
You might want to check the Registry for additional causes of oil leaks.
Old 08-27-2013   #5
Coolant "smoke" is actually steam, "white fog" and you may, depending on one's olfactory acuity, detect the smell of antifreeze...but not always.
I had a leak on the afore mentioned exhaust manifold bolt; same side too, as it happens. And, I believe too that the FSM is where I read to use some RED (aka high-temp) RTV on the threads and re-seat the bolt. (It fixed my leak!)
If you see blue-ish smoke, it is oil. And, if blue, and smells like burning oil...likely it is.
If you turn the engine off, after it gets hot enough to cause the smoking, and the smoke continues to rise from the 4-6 cylinder area, well that is directly above the afore mentioned header bolt.
FWIW,
P.
Old 08-28-2013   #6
max76
Hi hottrodcrazy,
the 4&6 plugs are on passenger side? If yes i have the same problem.
I try to go under the car but i cant see where is the leak. I think is oil leak from the odor.
Do you solved the problem???
How???
Thanks
Max
max76 is offline   Reply With Quote
Old 08-29-2013   #7
hottrodcrazy
Max, I haven't had a chance to investigate the problem further yet, so no I have not fixed it. Yes, plugs 4&6 are on the passenger side. It sounds like my problem, except that mine doesn't smell like an oil odor. It often smells like burning rubber, but not oil. I would suggest if you haven't read the suggestions above you read what the others have to say, I feel like it's probably as suggested that it's a header stud leak. Good luck with your issue!
Old 08-29-2013   #8
max76
Thanks hottrodcrazy...
Franke, how i can remove the stud???There's a nut to unscrew??
Thank you so much
Max
Old 08-29-2013   #9
Franke
Max, I've never performed the stud removal procedure. I think your going to need the service manual and maybe some one on this forum who did it before could help with additional info.
Old 08-29-2013   #10
The nut is "self locking" 15mm hex drive, threads are M10-1.5.
If the stud has been leaking, it will frequently come out when you attempt to remove the nut.
If the stud does not come out with the nut, then obtain 2 standard, M10-1.5 nuts and double nut the stud to remove.
