Old 08-15-2013   #21
scottfab
scottfab's Avatar
Default Re: Alternator Problems
Originally Posted by bldavis11 View Post
The link on the registry site doesn't seem to work. Can you point me in the right direction on how to rebuild our alternators?
Yes, I see that link is broke. Try this.
http://www.zr1netregistry.com/Inform...r-Rebuild.aspx
I am not sure why but this is the second link I've found that is broken this week. I'll investigate..
Scott
Old 08-15-2013   #22
bldavis11
Scott,
Still no joy. The above link redirects me here:
http://www.zr1netregistry.com/Information/TechNet/%5BAllArticles%5D.aspx
Ben
bldavis11 is offline   Reply With Quote
Old 08-15-2013   #23
scottfab
scottfab's Avatar
Scott,
Ben
Well the Alt rebuild is on that page but.....
if you act quickly this one may work for a few hours
Something is changing and changing a lot. Please stand-by
Scott
Old 08-15-2013   #24
WVZR-1
There's a quite good 2 part you-tube for the CS144 alternator build:
http://www.youtube.com/watch?v=riYZssdSmXY
http://www.youtube.com/watch?v=vKbX7mezuFM
I've not watched these in quite some time but I believe it's quite informative.
Old 08-15-2013   #25
bldavis11
Well, I missed it. I guess I'm mostly interested in where to purchase a rebuild kit (if available). I can probably work my way through the rebuild after looking at the parts in the kit.
Old 08-15-2013   #26
bldavis11
Those videos are invaluable. Holy smokes! Thanks for sharing them!!
Ben
Old 08-15-2013   #27
scottfab
scottfab's Avatar
The part number is right there on one of the pics.
Looks like depending on the browser you use the link is different.
This works for IE
http://www.zr1netregistry.com/Inform...ticles%5D.aspx
and this for Firefox
Scott
Old 08-16-2013   #28
WVZR-1
** I don't believe the kit in the image is for a CS144, not knowing the source of the thread with the image mentioning the rebuild but earlier in this thread Scott mentions only using a "portion" of the kit. I'd say that part number is NOT a "wise buy"!
Using that part # and doing some searching I believe if I were doing a rebuild and was interested in a quality build I might source the parts differently. Don't know but the part # or the kit doesn't display a voltage regulator. If there's a reputable automotive alternator/starter shop in the area I'd have a conversation there. Is there someone that does the municipal fleet work, fire ems services
An acquaintance was looking for an alternator a couple weeks ago and I suggested that if his were original I'd repair his rather than buy any "off the shelf" reman and he took his to a shop in the area and less than $25 he was out the door with an alternator repair. NOT a "rebuild" but a repair!
The bearings are very common and quality bearings can be purchased through most local bearing sources, there's cheap and there's quality. A kit that sells for the Amazon price and is in "multi-lingual" packaging has "other than quality" written all over it. There's quality bridge rectifiers and there are quality regulators also. I'd think I'd certainly shop and have a serious conversation before jumping on a "kit"!
Old 08-16-2013   #29
Dave
Where would you recommend purchasing a kit and what kind?
I have a spare kit and like to rebuild it to OEM specs
Thanks!
Old 08-16-2013   #30
WVZR-1
Originally Posted by ZZZZZR1 View Post
Dave
Thanks!
You have a spare "alternator" not kit? The "acquaintance" I mentioned was in Brookville PA and they have a local facility that I understand is well thought of.
In your area I'd think there are several. A local audio shop might have a local shop that they recommend for high amperage builds but you're not interested in all of that or "maybe" you are. I'd think you only need parts! Bearings are easy, there's choices in bridge rectifiers and regulators. Which alternator do you have by part number?
