05-28-2013 | #1 |
Drop in Dewitt radiator install pics......
The guy I sold my '90 to had a radiator leakage problem, so we went with a Dewitt direct replacement. Technically this is a drop in unit, and I did not need to modify anything....it was a tight fit though, and I found I had to persuade it a few times. Overall impression though is that this is a very nice option. We liked the all aluminum construction, as one of the plastic tanks failed at the plastic to aluminum tank seam on the old one, and it was only 2 years old. The construction and quality is impressive. I had to pry the fan shroud a little to get it to fit between the end tanks, other than that it fit well, and no modifications were required. I did have to undo the bottom bolts on the shroud, and then install the top bolts first, and install all bolts loose install, and then went back and tightened everything. Things did not want to align properly without doing it this way. I'm not sure if that is required with a stock unit. $325 represents a good value in my book, and this radiator has only recently become available.
2009 LS9 1990 LT-5/sold/Bought my Baby back 1994 Lingenfelter LT-5/sold 1973 LS4/sold |
05-29-2013 | #2 |
Re: Drop in Dewitt radiator install pics......
Pretty nifty handiwork there!
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] |
05-29-2013 | #3 |
What is the other radiator that is available? Is it a Ron Davis? Any idea how it compares costwise and build quality?
05-29-2013 | #4 |
There are several options out there.......most are north of $500 and most have thicker cores. The thicker core is a good thing, but requires trimming the fans shroud. This radiator is not a thicker core, but the tanks are said to provide more capacity, and the website says it provides 50% more cooling surface over stock, with no modifications.
I really like the all aluminum construction over plastic end tanks.
06-04-2013 | #5 | |
Do you have links to the place you purchased? Would sure like to look into this option/price point.
Thomas (looking towards my own LT5 designation :-)) |
06-05-2013 | #6 |
I went with the Fluidyne. I don't remember what it cost but it was expensive. Looks good though. Once installed, you can't see it anyway.
If you get this radiator and you have Samco hoses, the top hose will be difficult but not impossible to install. I had to grease the inlet pipe with silicone and make a shoe horn out of a piece of a plastic bottle which I also greased to get the hose on. I'm not sure if residue from that silicone getting into the coolant is ok or if it will cause a problem later. |
06-05-2013 | #7 |
We ordered directly from Dewitts. Took a couple of weeks. This is a relative new product, and I don't think they keep very many on hand.....may even be made to order.
http://www.dewitts.com/collections/c...minum-radiator
2009 LS9 1990 LT-5/sold/Bought my Baby back 1994 Lingenfelter LT-5/sold 1973 LS4/sold Last edited by WydGlydJim; 06-05-2013 at 03:25 PM. |
