05-25-2013 | #31 |
Re: Initial thoughts on Pete's Intake/Exhaust cam combo
453sh at the wheels @6868 rpm...Extreamely NICE! There is tons of "meat" under that torque curve, to be sure. Congratz! Looking forward to how it runs at Monee next weekend!!
P.
05-25-2013 | #32 | |
How is the idle with the cams? Does it idle like stock, nice n smooth, or is it choppy, like a big cam race car? Nice numbers too!
1993 ZR-1 #211 Yellow On Beige Beast #2 1992 ZR-1 #427 Black On Black *Sold* 1985 L98 Blue On Blue *Sold* |
05-25-2013 | #33 |
Yeah Paul. No less than 350rwtq from 3700 to 6700 rpm. Rather broad torque curve.
05-25-2013 | #34 | |
More valves are better than 1.
07-08-2013 | #35 |
Once I got the vacuum leak issue resolved (loose fuel rails), I started datalogging again to refine the part throttle tune. I don't think the vacuum leak would affect WOT much due to equal pressure inside and outside the intake tract. Pretty much have it dialed in now ( famous last words, right Todd ,
with idle in the 875-925 range, and IACs at ~20. Had an opportunity to take a long drive w it and recorded 23mpg @ 75-80mph. After about 600miles, the tailpipes are not sooty but more of a golden color w the chrome visible under the slight film. WB registering 14.5-14.9, and BLMs ( running and idling in Closed Loop) avg. 127. Ran like a champ and blew off a few pretenders along the way at part throttle. So overall, the motor drives and runs well, idles and doesn't stall.
07-08-2013 | #36 | |
AL. |
07-08-2013 | #37 |
Al,
As usual, just one more tiny, little, itsy bitsy small tweak. Trying to see if I can get it to idle at 850 w IAC counts. Might try to do some "smoothing" next. Maybe. Or maybe I'll leave it alone and just drive it without a laptop on the passenger seat.
07-14-2013 | #38 |
After addressing the loose fuel rails and reading a bit more on the 3rd Gen forum, I started playing with timing at idle. Also continued to lower the IAC counts in the MAT table. Taking the car out for a drive in the lovely Chicago weather we are having my idle IAC counts were at 15. What's really nice is that the motor idles more smoothly and at ~ 850. I initially had idle timing set at 21d, now it's at 17.
So I am thinking that my IAC counts were disappearing because the timing was keeping the motor from idling down any further and as motor got hotter it was more difficult to bring down the idle. Another lesson learned. Thanks again RBob.
07-14-2013 | #39 |
Pete, That is because he is trying to increase fuel economy by using nothing but 6th gear.
Robert J. DeMarco [SIGPIC][/SIGPIC] [COLOR=blue]G[/COLOR][COLOR=red]rand[/COLOR] [COLOR=blue]S[/COLOR][COLOR=red]port[/COLOR] Registry Lifetime Member NCM Lifetime Member #2655 Pacecar Registry Member [COLOR=red]ZOOM Charter Member - ZR-1 Owners of Michigan[/COLOR] [COLOR=plum][I]ZR-1[/I] Registry member since 2012 [/COLOR] [COLOR=black]1990 LPE "368" Aerobody ZR-1, Last ZR-1 built by John[/COLOR] 1991 Callaway Aerobody ZR-1, DRM 500 1991 Shinoda Aerobody Spyder, 1998 Pace Car |
