05-20-2013 | #1 |
Clutch slave
Hi does anyone know who sells a steel clutch slave cylinder replacement. All I can find is the cast model I would rather have the steel one and not the cast one. Or possibly a rebuild kit would do also. It's for a 1990 zr1.
Any help would be appreciated Bob |
05-20-2013 | #2 |
Re: Clutch slave
05-20-2013 | #3 |
Re: Clutch slave
http://www.rockauto.com/catalog/more...272&cc=1041275
and also http://www.rockauto.com/catalog/more...431&cc=1041275
05-20-2013 | #4 |
Re: Clutch slave
Thanks guys I have a call into zf doc if he can't help I will try Powertorque Systems. I tried rock auto but they didn't know what they had cast or steel didn't get a warm feeling. Too bad I have used them in the past but the tech couldn't take a look to see what he had in stock.
Bob |
05-20-2013 | #5 | |
Re: Clutch slave
05-21-2013 | #6 | |
Re: Clutch slave
Rockauto has both cast and steel. They list about 6 or 8 that fit the 90. The links I sent are the two steel ones going by the pics. The others were obviously cast going by the pics. When I replaced mine I used a cast part.
05-21-2013 | #7 |
Re: Clutch slave
Jim at PowerTorque rebuilt my master and slave. Only way to go, as many of the new units may be misassembled. I had the cast units in my Z while I waited to get the originals rebuilt and they just don't feel the same. Call Jim. He's a great guy to work with
Jim |
05-22-2013 | #8 |
Re: Clutch slave
Made contact with Jim at power torque systems and am buying one from him. Thanks for all the info and help.
Bob |
05-22-2013 | #9 |
Re: Clutch slave
If you don't close there, I have all the hardware from my '90 ZF after doin' the auto conversion; 'Doug' has 1st dibbs on the tranny - if you're interested, I can get up with him to see what other parts he might want... (hardware has 32k on it).............
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] |
05-28-2013 | #10 |
Re: Clutch slave
I'm pulling mine out to fix the leak. I used to be a Girling Distributor, and had new ones years ago. When I take it apart, I will see if I have the seal kit needed. I have built tens of thousands of power brake units. Many seals will interchange on cylinders. IF I figure out the seal kit, will there be anyone interested in ordering? you can see my videos at youtube.com/powerbrakeservice
