#31 |
Sure you can, once i get the harness made, right now it's a rigged up harness and only one coil firing on the 4 pin VW.
#32 |
![]() Join Date: Jan 2009
Based on numerous circuit simulations I predict NO dwell issue what so ever. The Ferrari wire harness is MUCH more stout than the ZR-1 and can most easily handle the current. And I suspect the fuse adjustment, if needed, will be trivial.
#33 |
Excited to see what you have done here.
#34 |
![]() Maybe Scott could re-breath life into your LSX coil project Dom?
#35 |
#36 |
Not familiar with that thread. Maybe I can be pointed at it and/or a new thread started?
#37 | |
Here you go Scott http://www.zr1.net/forum/showthread....t=coil+project
