Old 02-27-2013   #1
Nacho_ZR1
Default Rear wheel HP estimate
Greetings from Moscow! Quick question - realistically how much rwhp can I expect with ported heads/IH and Pete's cams. Also, what trap speeds and mph are ya'll running in the 1/4? Once i get back from my biz trip, I'll be taking my car to Corey so he can work his magic!
Nacho_ZR1 is offline   Reply With Quote
Old 02-27-2013   #2
Default Re: Rear wheel HP estimate
420-440rwhp; traps at 120-125, depending on how good a driver you are and tires you use
Old 02-27-2013   #3
Hib Halverson
The Automasters "Street Skinner" engine in my 95 made 413 SAE-corrected at the wheels on a DynoJet with stock manifolds and cats.
If you add headers and cams to a 350 with head/housings/plenum work and cams I'd hope for at least 430 at the wheels. Anything less and I'd want my money back.
I'd say your speed in the quarter will be 120-130. As for the e.t? That will depend on your driving talent, axle ratio, rear tires and your suspension set-up.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 02-28-2013   #4
Fully Vetted
Fully Vetted's Avatar
I've got right at 420 to the wheels without cams. Pete did the port work and the SW headers. Have not been to a track.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 02-28-2013   #5
Hib Halverson
420 at the wheels..SAE-corrected or standard-corrected?
Hib Halverson
Technical Writer
Old 03-01-2013   #6
Fully Vetted
Good question. Corey did the pull last month. I'll be picking the car up here pretty quick. I'll ask.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 03-01-2013   #7
Pete
Pete's Avatar
When i dyno'd that Z it made 425 SAE Corrected
I heard Corey got 428 out of it.
I think 430+ should be possible from that Z but then again every Dyno is different 420-430 is withen tolerance
Some shops have unfriendly dyno #'s till you drop some cash then they get you some friendly dyno #'s.
This is why i always dyno'd at two different Dyno's just to compare.
Look up Dynojet tricks how they can play with Dyno #'s
What i have discovered at my 600ft elavation track and my Z with stock front wheel/tires.
370-380rwhp 115-117 1/4 MPH
390-410rwhp 117-119 1/4 MPH
415-430rwhp 119-121 1/4 MPH
435-450rwhp 121-123 1/4 MPH
465-475rwhp 128-129 1/4 MPH aluminum pullies half weight over stock saves 2.5lbs,ATI balancer minus 2lbs,flywheel/clutch set up saved a bunch
(200lbs overall total)
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 03-01-2013   #8
Pete,
You've got the last 25 rwhp making a 5+ MPH trap speed?
Old 03-01-2013   #9
Pete
Pete's Avatar
Pete,
Since then i re-ported my plenum/IH's a bit bigger i also mention i reduced rotational weight between pullies,ATI balancer,clutch/flywheel i'd say 25lbs maybe more and about 200lbs dead weight.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 03-01-2013   #10
Nacho_ZR1
Pete
Wow how'd you reduce 200lbs? Inquiring minds wanna know
