Old 02-25-2013   #1
Vetman
Vetman's Avatar
Default synthetic oil for LT 5
I understant Mark Haibeck recommends AMS oil synthetic for the LT 5. There are a number of types of AMS oil synthetics. Which is the best one for our LT 5 engines and is there another brand anyone else would recommend. Also, which oil filter is most effective holding oil?
1990 Z # 2441
1959 c-1 230 HP 4 speed frost blue/silver 3 owner
2011 cts-v 556 HP, manual 6 speed
1955 chev 2dr ht PP 265 3 speed w/OD
Vetman is offline   Reply With Quote
Old 02-25-2013   #2
efnfast
Default Re: synthetic oil for LT 5
Marc recommends the Amsoil 10-40 high zinc. He also recommends the AC Delco AC970C oil filter. I run both of these.
Old 02-25-2013   #3
I use Mobil 1 High mileage 10-30. Mobil 1 High milege 10-30 has 1000 ppm of phosphorus and 1100 ppm of zinc.
Old 02-25-2013   #4
Vetman
Vetman's Avatar
Amsoil had two 10-40 synthetics. one is 10-40 XL for 7.95. and the other is 10-40 premium for 10.10. The more expensive appears a little better on the test results posted. Also has a longer extended life service. Is the more expensive one necessary? Suggestions? My LT 5 is stock, 61,000 miles and runs perfect, right to 7000. Car is not raced. I just love the smooth, massive power and historic significance of the ZR-1.
1990 Z # 2441
Old 02-26-2013   #5
SteelBlueZR1
I also use Mobil 1 High mileage 10-30, which Marc approves for the LT5 and is easy to find at WalMart.
Bert Rankin
1991 ZR1 Steel Blue / Steel Blue
#1029
Haibeck chip, slotted rotors, camber brace, C-beam plates, OBX exhaust, Nitto NT555 tires
[SIGPIC][/SIGPIC]
SteelBlueZR1 is offline   Reply With Quote
Old 02-26-2013   #6
i've been using normal mobil one, i need to switch to high milage
Old 02-26-2013   #7
efnfast
High zinc levels are what is important. Old oils had higher zinc levels, the new oils don't. That's why most of us run some special oil.
Old 02-26-2013   #8
HAWAIIZR-1's Avatar
I used to use AMSOIL AMO 10W-40 as recommended by Marc, but just switched to AMSOIL ZROD 10W-30 after recommendation by AMSOIL and one of their reps. A case is on the way so I have not actually tried it yet. After seeing what Yun and others are using with Mobil 1 high mileage 10W-30 I may use that instead with it being so easy to get and no shipping to pay for. I just mailed off an oil sample (Blackstone Laboratories) to see how the AMSOIL AMO 10W-40 is doing after rebuild break in and what the phosphorus and zinc actually is.
As for oil filter, check out all of Marc's research and you can't go wrong: http://www.zr1specialist.com/HAT%20W...ers%202006.htm
I bought a case of Fram TG3985 for about $2 each when Rockauto.com had their closeout so I guess I have a lifetime supply and I see Marc has updated recommendation since.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 02-26-2013   #9
Starman
Starman's Avatar
I use a 50/50 blend of Red Line racing and street oil. Both are high in the EP additives, but this is not a cheap option.
Old 02-26-2013   #10
Craig.......I use AMSOIL 10W-40 as Marc suggests/suggested. But may switch to AMSOIL 10W-30 (where it is colder) if it is essentially the same except for weight. Let us know what Blackstone says
Cliff
