Old 02-21-2013   #11
Pete
Pete's Avatar
Default Re: Bought Out A/O Engineering's Leftover Stock
Brett, all i need is the front cover piece.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 02-21-2013   #12
Blue Flame Restorations
Not true there is a cutting procedure and of course the front plate is different
Brett look at those directions I sent ya the MY 90 is discussed
Yes, I still have the data you sent. The 90 is mentioned. Since I have a 90 body tub, I will make sure eveything is a direct fit, including all instructions for installation for each year, 84-96. This is not just for ZR-1's.
I will R&D the ducting and clamp system and most likely use my own attaching system and industrial grade ducting.
My BFR Air-Blast kit will provide similar air induction characteristics but will not be a 100% copy of A/O's discontinued kit.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 02-21-2013   #13
RICKYRJ1
RICKYRJ1's Avatar
I aggree, cutting has to be done.
Old 02-21-2013   #14
WVZR-1
I may actually have one of their air-cleaner lids. Do you need one to duplicate or are you doing your own?
Old 02-21-2013   #15
I'd love to have one for just R&D for a few weeks.
Old 02-21-2013   #16
VetteVet
VetteVet's Avatar
Originally Posted by cvette98pacecar View Post
Brett, Are you going to offer a kit for the Widebody's? Basically a fresh air inlet that is being supplied by the radiator opening?
What did AO call the kit that Robert is referring to? I have the inverted housing, but am lacking the filter cover with the scoop that picks up air from the radiator opening. Does anyone have an extra one of those pieces?
Thanks,
Jep
VetteVet is offline   Reply With Quote
Old 02-21-2013   #17
Thanks,
Jep
I think I've seen them but not sure who made them.
Old 02-21-2013   #18
VetteVet
VetteVet's Avatar
Brett,
I could have sworn that my inverted housing had A.O. Engineering molded into it. I just went out to the garage to check and found out that I was mistaken. It has:
Automotive Performance International Inc
Seattle, WA
I'll be damned! I don't know why I thought it was an A.O. piece.
Jep
Old 02-21-2013   #19
sammy
i have 2 of the inverted setups (the one where you have to cut the radiator cover .i could send you one to use for mock up if you like .would like it back when your done . but more than happy to send it to you .please pm me your mailing add if you would like to use it .
Old 02-21-2013   #20
VetteVet
VetteVet's Avatar
Sammy,
PM sent.
Thanks,
Jep
