View Poll Results: What would you go for?
Finished unit for $50ea (2 needed) 10 58.82%
Kit for $25ea (2 needed) 6 35.29%
Other (reply in comment with specifics) 1 5.88%
Multiple Choice Poll. Voters: 17. You may not vote on this poll
Old 02-06-2013   #31
Default Re: Under Hood Lighting
Originally Posted by PhillipsLT5 View Post
I am interested in under hood, I do have a switch now that turns them on/off
Will that still work?
Yes Phil since this is a direct bulb replacement. Cant wait to get my hands on a pair of these.
Old 02-06-2013   #32
I designed and assembled them yes. All parts are easy to get if you know where to look
Sign me up for a pair. I would need to have these built as I suspect most of the membership will.
Old 02-06-2013   #33
scottfab
scottfab's Avatar
Ok I'm doing a poll to see how much trouble I'm getting into.
This poll is for 7 days ONLY. Anything after that may or may not get serviced since this is not a business for me. I design things. That's the fun part Cranking things out is drudgery.
Scott
Old 02-06-2013   #34
First in your poll Scott do you take Paypal? GC
Old 02-06-2013   #35
alwayscode390
Arrow Re: Under Hood Lighting
I noticed my underhood lights don't turn on, are they supposed to come on when you lift up the hood?
I wonder now if I have a switch , or if they are just burnt out.
If they are burnt out, is that common since our cars are pretty old now?
If there is a switch ... where is the common place to install it (where should I look?)
Thanks ---
[SIGPIC][/SIGPIC]
01' Dodge Viper GTS
11' Ford Raptor
90' ZR-1 Corvette LPE #699
Old 02-06-2013   #36
scottfab
scottfab's Avatar
Yes, paypal will be fine but not quite yet. Based on the numbers I have to see if I need to hire someone to make these for me
Then I'll post pay options.
The assembly is not really trivial
Scott
Old 02-06-2013   #37
scottfab
scottfab's Avatar
Thanks ---
I'd check to see if someone unplugged the connector. It's located just to the right of the passenger side headlight. Follow the wire down to it.
Next check the inline fuse. Maybe it was removed.
Then look for any switch that may have been installed. Most are put in the cove under the drivers headlight.
Lastly you can inspect to see if the bulbs were just taken out or are popped. The mercury switched would be last.
You can tap on them to see if they've become intermittent.
Scott
Old 02-06-2013   #38
YES
Both are possible and the switch is aftermarket. Its also more likely the previous owner unplugged the lights or pulled the fuse
Not common one maybe out but not both my money is they are unplugged or switched. Start following the harness.
Thanks ---
It could be anywhere however mine is on the drivers side next to front of the tire in the engine compartment.
Old 02-06-2013   #39
alwayscode390
Thanks Scott and GC ... if I can get these working I may be interested in the GP too ---
[SIGPIC][/SIGPIC]
01' Dodge Viper GTS
11' Ford Raptor
Old 02-06-2013   #40
Ronstar
I want a set
Ronstar is offline   Reply With Quote
