Old 01-21-2013   #21
Default Re: The dreaded #8 plug, improved
Looks like the plug socket with the attached swivel, + short extension + another swivel on that...is pretty popular. Interesting how so many came up independantly with a similar solution.
I guess I can still remember changing plugs on my 95 LT1 Vette. Next to that, plugs on the LT5 are child's play! (I once had to jack up the front end on jack stands and get to the #8 from underneith; a real PIA!!)
P.
Old 01-21-2013   #22
Hog
Try changing plugs on a 93-02 F-body (Camaro/Firebird) with 1/3 of teh enginbe under the cowl. Y-body guys have it easy on comparison.
Old 01-21-2013   #23
P.
Paul,
Slant plug heads made it a bit easier on the SBC.
Old 01-21-2013   #24
i've never considered #8 that hard to change
Old 01-22-2013   #25
Fully Vetted
Fully Vetted's Avatar
Yeah, I haven't either.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 01-22-2013   #26
scottfab
scottfab's Avatar
Exactly. Not much of a challenge really. It's kinda like getting the POS air cleaner screws back in.
10% effort and 90% technique.
Scott
Old 01-22-2013   #27
Jim Nolan
That's too many angles for me. I take the plug socket plus 2 each 3/8 universals and put small stipps of duct tape to keep them together. Then I use a 3/8 to a 1/4 stepdown and use my 1/4 rachet to install and torque, that's straight in. No harder then the rest. With the universals and the stepdown I can install the plug by hand until ready to tighten.
Old 01-26-2013   #28
Hib Halverson
Agree w Hib on this. I use a 5/8" deep with 3 U joints attached. That snakes it into the plug well. Then a 1/2" drive breaker bar. Once loosened, I can finger turn plug. Once undone, put a telescoping magnet and pull plug out.
To install, I can put plug into rubber hose to screw it in, then reverse the removal process for final torquing. BTW, I use a thin film of oil on the thread to eliminate seizing of plug.
Curious about the 1/2-drive breaker bar
Seems an awful big too for spark plugs. How much do you tighten those suckers when you put 'em in?
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 01-26-2013   #29
Paul,
Ummmm.... Mebby so, but I can change all 8 on the LT5 before I could barely get a friggin socket on #8 on my LT1. I don't recall if they were angled or not - I wanna say NOT. But, I've slept since then...
P.
