#11 | |
![]() Join Date: Oct 2004
The package part # is 19179359 and it's an 18 X 4 complete with tire, compressor and accessories. Last edited by WVZR-1; 01-01-2013 at 04:41 PM. |
#12 |
![]() ![]() Join Date: Aug 2005
So any new recommendations on what to use as a spare
over C6 Z06 calipers other than Fix-A-Flat? |
#13 | |
Well I know your not running wheel sensors DOM but Fix a Flat will hose those up for sure if you were. All things considered a Triple AAA tow or I have towing via my insurance CO to the nearest facility. Or leave it there if you can pull the wheel etc.
#14 |
![]() Join Date: Jan 2010
tire plug kit
wire cutters (for pulling out nail) 12v compressor (plug into cigarette lighter) fix a flat, just a squirt (may help plug seal) of course if you ripped a big hole in the tire you're screwed... AAA card, "don't leave home without it" (especially in a 20 year old car) |
#15 |
![]() Join Date: Feb 2011
Maybe the elusive CTS 18" spare might fit...almost certainly it could with a spacer. I thought about picking one up for my C6, but i have not been looking lately.
I'm running the 17" GTO spare with my C5 caliper conversion on my 91 though. Been there-done that on the whole not having a spare when you need one thing. |
#16 |
#17 |
The 18" CTSV should wholesale for maybe $360 or so and most/some Cadillac dealers stock them. If you've got a "relationship" with one you could maybe arrange a "trial fit". I supplied the correct part number I'm quite sure. Need to remember the bolt circle for the GTO and the CTS-V is 120mm not 120.7 or the implied 4.75". It's not considered an issue!
I believe I've come across a "stumbling block" the CTS-V is only a 66.9mm center-bore so the wheel center would need opened up to the 70.3mm dimension. There would be no sure "trial fit" but I would think it would slip over far enough to confirm that it would be a "go"! Actually a GTO should require a minor trim for fit also for those interested. It's 69.5mm I believe. "Mike100" should be able to confirm the "minor" modification required. It might "force fit" being less than 1mm difference. Last edited by WVZR-1; 01-01-2013 at 09:29 PM. |
#18 |
![]() ![]() Join Date: Feb 2010
Yep, I had to trim the hub hole on my GTO spare.
I do have AAA Road Insurance though.
1988 KOH Prototype EX5023 sold 1990 ZR-1 #444 Convertible 1990 ZR-1 Black #966 1991 ZR-1 Quazar Blue #296 1957 Duntov SS Project Last edited by Blue Flame Restorations; 01-02-2013 at 02:20 AM. |
#19 |
From CF -
The CTS spares require a 1/2 spacer/adapter.......the GTO spares require a 3 1/2 adapter. This to clear C6 - Z06 brakes. I lost the link and was going to post a couple snapshots. I thought I had read 3 1/4 previously for the GTO spare but couldn't find it the 2nd time. The spacer/adapter price would kill that idea! |
#20 | |
Tags |
emergency, flat, spare tire |
