#101 |
Pantera and Daniel, you guys are just great! I really appreciate all of the input. I know I am a little anal about this stuff but I figure there is no point in reiventing the wheel when guys as nice as you have been willing to answer my questions. I started on the rear and now with this info I can probably get the rear done monday with my schedule. Thanks again guys I really really appreciate your help. I am sure I will have more questions and it is great to know I can count on the help. I hope I can repay one day. Have a Merry Christmas!!
#102 | |
![]() Join Date: Jun 2004
I'll email you a pic of the cutter you'll need to make a clean hole in minutes ![]()
#103 | |
![]() Join Date: May 2010
Okay, thanks. It's not like I'm in a rush or anything and appreciate it. ![]()
#104 |
HawaiiZR-1, Saw your post. I used a bi-metal hole saw that fit perfectly just inside Carters bracket. I remember last time doing this I used a dremel tool and it took forever. With the bi-metal hole saw and an 18 volt drill it took about a minute. I could not believe it. Sure made the job easier and a nice cut as well. Good luck.
#105 | |
http://www.youtube.com/watch?v=Zf95A-OuzAs So something like this, correct? Craig
#106 | |
![]() We'd have to cut dimension C in half, and reduce dimension A a bit? B and D would remain unchanged? |
#107 |
/\ /\ yes
#108 |
Awesome, thanks!
One last thing, the rear shocks had two metal washers if I recall. One is gold-colored and slightly concave. The other is black and flat. The gold one goes on top of assembly I just pictured, between the rubber and the FX3 "crown". But does the black one go on the very bottom of the lower rubber? Or somewhere else? |
#109 |
I knew I could count on Bob. That drawing is perfect. It is amazing what can be done to solve a problem. Thanks everybody! I am really looking forward to getting these coilovers on. Hopefully with Bobs help we can finish up the rears today. Not exactly looking forward to the fronts but with all of the help and resources available I am feeling pretty good. Thanks again.
#110 |
Well, Merry Christmas!! Bob and I worked on the rear today hoping to finish it up but we didn't quite get there. Holes drilled per Carters bracket, trailing arm bolts reversed, bushing cut and shocks/coils assembled. Trying to mount the shock/coilover we cannot seem to get the carter plate to line up with the holes. It is about a 1/4" short of lining up to the hole towards the front of the car. I drilled out the area revealed when I bolted up the carter bracket but we cannot seem to get it forward enough with the assembled shock, bushing, carter bracket etc. It is as if the bushing will not allow us to get unit moved toward the front of the car so that the bolt holes will line up. Is the area revealed by carters bracket the ONLY metal that needs to be removed. The frame that was visible through the hole in carters bracket is removed. Again, any help would be appreciated. It is puzzling. Best wishes for a Merry Christmas to all.
