Old 12-10-2012   #1
Marc Haibeck
Default ECM Interchangability
I was wondering about ZR-1 ECM interchangeability. I did some testing and it appears that any model year ECM will work in any car. That is a 1990 ECM will work in a 1995 and a 1995 ECM will work in a 1990. The details of the testing are described below.
GM used three ECM part numbers across the six model years.
01228331 1990 to 1991.
16163993 1992 to about 1993 1/2.
16196394 about 1993 1/2 to 1995.
AC/Delco supplied the 16163993 as a remanufactured unit for repairs from about 2004 until about 2009. They shipped 16163993 regardless of what model year was ordered.
I removed a factory installed 1990 01228331 from a 1990 car. Then installed a 1995 BMCB calibration chip and installed the ECM on a 1995 car. Everything worked normally. The engine went into closed loop fuel control, it went into learning mode, the EGR worked normally, the ASR worked, the momentary contact full power key worked, and the engine data scanner displayed engine rpm with a resolution of 1 rpm. The ALDL data stream ran at 6.6 frames per second, just like a 1995 ECM.
I removed a factory installed 1995 16196394 ECM from a 1995 car. Then installed a 1990 AYBK calibration chip and installed the ECM on a 1990 car. Everything worked normally. The engine went into closed loop fuel control, it went into learning mode, the full power key worked. The engine data scanner displayed engine rpm with a resolution of 25 rpm. This is normal for a 1990 car. The ALDL data stream ran at 6.6 frames per second, just like a 1990 ECM.
A 16163993 ECM was tested in a 1995 car and it worked normally as a 1995 ECM would.
[/SIZE]
Old 12-10-2012   #2
Blue Flame Restorations
Default Re: ECM Interchangability
Good info to know. I have a rebuilt ECM in the box for a rainy day.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 12-10-2012   #3
93 ZR1 Barcelona
93 ZR1 Barcelona's Avatar
Very interesting information to know.
As allways, thanks for all your dedication Marc.
=D>=D>=D>
93 ZR1 Barcelona is offline   Reply With Quote
Old 12-10-2012   #4
QB93Z
QB93Z's Avatar
Thanks Marc.
This information opens up a lot of options for keeping the ZR-1 Fleet healthy.
I am always impressed with the thoroughness of your testing. Is it OK if we print this in the Newsletter?
If it isn't fun, you aren't doing it right!
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 12-10-2012   #5
Marc,
I made sure the ZR crowd on CF also got the benefit of your research.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 12-10-2012   #6
Torchred96
Wow, Just remembering that one of the determining factors for buying this car instead of another lt1/4 was the fact that people like you and the existence of this forum gave me the confidence to take on a 140k mile Z car with hardly a second thought. I probably would have passed (and with good reason as it turns out) on it otherwise.
I seem to remember thinking I should stay away from a certain MY just because of the ECM issue, which If I'm reading this correctly is a non issue now?.
Thanks for all your hard work and ESPECIALLY your willingness to share as much as you do.
Sam
1991 ZR-1
:salute:
Torchred96 is offline   Reply With Quote
Old 12-10-2012   #7
Sam,
Let's just say that with this information re:interchangeability and reliable sources for reman ECMs, availability is less of a problem than we thought.
Now if we could find someone who could re-write some of the code.
Old 12-10-2012   #8
Sam,
or a supplier for DIS modules............
Old 12-10-2012   #9
Re-writing the code could be a step towards eliminating the DIS. Having said that, the module itself is a pretty stout piece.
Old 12-10-2012   #10
fantastic news marc, thanks for all you do for us
