Old 09-25-2012   #1
Corbusa
Default Brake rotor questions
I didn't want to hijack xFires thread so I'm asking here. I looked on eBay just to see what is out there and I'm sure you get what you pay for . But just in general will the slotted rotors do a lot better job than stock ones?
I found sets starting at $135.00 and up...
I do know the extra piston and size of the zo6 should make a huge difference , but as I slowly progress , I'm just curious if the factory size rotors being drilled and slotted will be worth the efforts?
Old 09-25-2012   #2
Default Re: Brake rotor questions
I've a friend that drives the road course circuit, and I asked him pretty much the same thing. He showed me a couple stock, cast iron rotors off his car that were cracked, and blue/black from heat. His point was unless you go really big (read:really exotic and expensive) the cast iron is best sans drilled (especially) - slots OK, but not worth the cost, far as braking improvement goes.
From a bling point of view, cheap might be OK, long as you don't road course...is what I took from that. Road course abuse seems to be the dividing line, from what those that do say.
Twould be interesting to see what uther roadies have to recommend.
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 09-25-2012   #3
To do "cross drilled" rotors properly, the holes should be cast into the rotor and the holes chamfered as done by Porsche. Simply drilling rotors results in the cracking Paul points out. Also the drilling can weaken the rotor if the drill through the inner vanes.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 09-25-2012   #4
For an entry level upgrade to brakes for the ZR-1, I suggest the following;
Rotors: about $400 for 4 wheel set http://www.powerslot.com/
PowerSlot rotors, you can choose from std to cryo treated. Slots offer de-gassing & cleaning benefits of the drilled rotors, but without the stress cracks prevelant in all but the most expensive rotors
I have owned them and never incurred any "hot warpage." Most other entry level, slotted or drilled rotors I've owned have ultimately developed rotor warp when used moderately. OK when cool but pulsating pedal when hot.
Brake Pads, abt $200 for 4 wheel set
Performance Friction: This a top shelf manufacturer. They make a variety of pad compounds and are used in professional motorsports. I recommend the carbon-metallic, Performance Friction-Z pads.
Link to Performance Friction
http://www.performancefriction.com/a...rake-pads.aspx
Link to O'Reilly's Auto Parts: Distributor
http://www.oreillyauto.com/site/c/de...0068&ppt=C0009
Calipers, abt $300.00 (optional)
The first shortcoming of the stock calipers is the lack of heat dissipation. For drag racing or street driving, not a problem. The first level of upgrade would be to 96 Grand Sport calipers. Look good, and aluminum dissipates heat faster. My recommendation for entry level.
Brake Lines, abt $100
Switch to a good quality, braided stainless steel line, for firmer pedal. If yours are original, they are old and probably deteriorated.
Brake fluid, abt $8.00Valvoline Dot 3/4 Synthetic
http://www.napaonline.com/Catalog/Ca...458_0337002502
Switch to synthetic. Lots of tech data out there. Wet & dry boiling point is a principal factor for me. Valvoline meets the standard very well and is affordable & readily available. Pressure bleed/flush complete system with new fluid until clean.
This will get you in to a very good system for about $1,000.
For a 4 piston Brembo, aluminum hat rotor system, be prepared to spend $5,000 plus. Lots of good selection both below and above this level. I would venture to say that most brake upgrades are done for the bling factor rather than outdriving the stock system's capability.
Old 09-25-2012   #5
Corbusa
Thanks Bro, Thats a load if info... When ever you guys write stuff like this up I print it out for future use, and put it in a folder.
I'll be talking to you soon..
Old 09-25-2012   #6
Paul in SC
Paul in SC's Avatar
I just added the GS Calipers, Powerslot Slotted rotors and Hawk HPS pads. I haven't pushed the envelope with them yet but they are a big improvement over what was on it before. Drilled originals (Baer) were cracking in several places; stock pads. The car had only 32,000 at the changed and I don't know how long it had this setup.
I am especially very pleased with the lack of dust from the Hawks. Helps protects the Fikses.
Overall, good first level improvement. Also went with the DRM bias spring...nice change as well.
I have a very good friend that drives SCCA pro and he goes with custom everything (Coleman Rotors). His recommendation and what most racers use is solid or slotted rotors. Drilled are a no-no.
Good luck and have fun. It's exciting to feel the difference when you make the move up...even better if you go for broke. Maybe next time.
Paul
1993 ZR-1 - "The Green Thing", LPE/LSV 385; 2021 HTC, Red Mist Metallic, Cool gray interior, stainless dual stripes; ZR-1 Net Registry #1376
Paul in SC is offline   Reply With Quote
Old 09-26-2012   #7
mike100
http://www.summitracing.com/parts/EBC-USR7010/
I'm real happy with these EBC rotors (I have the C5 brake conversion). semi-slotted- EBC claims quieter operation over full slotted and it has proven to be much more heat tolerant over my previous chinese parts store rotor and ceramic pad combo. I'm using Hawk HPS semi-metallics this time around.
Old 09-26-2012   #8
Corbusa
Do they make or are these the same size as the original rotors? The set up looks great - price isnt bad, pretty close to the powerslots Jerry listed .. I would just want to get the best brakes I can without having to change rims, tires , bla bla bla.
where's the best place to get stainless lines?
Old 09-26-2012   #9
Corbusa
After careful reading it seems the Powerslots are a Factory replacement ( answered my own question ) also cryo.
Old 09-26-2012   #10
This article is one I can attest to for accuracy by its applicaton to my brakes in several different cars/brake jobs now over several years (since this article came out).
A good read. Check out the article regarding warped rotors and other myths. I've never had a "warped rotor" since studying this article, and neither has my wife since coaching her on braking on especially hard stops.
http://www.stoptech.com/technical-su...nd-other-myths
P.
90 #1202
Sans secondaries
