Old 08-22-2012   #1
crjspo23
crjspo23's Avatar
Default Rough Running Z
I posted some history under another thread for Cam Position Sensor, but here is the problem. After no issues for 2 years, the car started missing suddenly about 10 seconds after startup. The SES light came on and was traced to fault code 31 - Cam Position sensor. The sensor was checked and determined not to be the problem, but in the course of suspicion of the common injector problems in 90-92's a couple of bad injectors were found. New Delphi SS injectors were ordered and installed, but upon startup the car still ran as if on 5-6 cylinders and then stalled and wouldn't restart. Fuel pressure was checked and is fine. Spark plugs were pulled and checked and are fine and do not appear to have been flooded with fuel and we do have spark.
Anybody got any other ideas of where to look to find this elusive problem?
Charlie
1990 Dark Red ZR-1 formerly owned by Chip Miller
crjspo23 is offline   Reply With Quote
Old 08-22-2012   #2
mike100
Default Re: Rough Running Z
do a compression and/or leak-down check on the cylinders.
Old 08-22-2012   #3
gbrtng
gbrtng's Avatar
something under the plenum is out of ordre - hosed up during the injector replacement.
Old 08-22-2012   #4
Yep Bent pin etc, check the wiring you might have pinched something
Old 08-22-2012   #5
rhipsher
rhipsher's Avatar
Check to see if the MAP hose is unplugged.
Old 08-23-2012   #6
crjspo23
crjspo23's Avatar
Actually traced back to a bad ECM. Anybody know sources to find one or get one rebuilt?
Charlie
Old 08-23-2012   #7
gbrtng
gbrtng's Avatar
A good possibility - what led you to that conclusion?
Old 08-24-2012   #8
tccrab
tccrab's Avatar
New ECMs have become very scarce and very pricey indeed.
I remember a thread a few months ago which referenced a company that refurbished our particular ECMs.
I will have to go digging around to find it.
Don't get false hope if you should find an ECM listed on some car parts web site.
It'll be for the L98 or the LT1 not the LT5.
Check with Marc Haibec, he'll either have one or know where to get one.
'Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 08-24-2012   #9
ScottZ95ZR1
ScottZ95ZR1's Avatar
I have a known good, used ECM out of a low-mile '91. I'm really not looking to sell it but if you absolutely can't find one send me a PM.
ScottZ95ZR1 is offline   Reply With Quote
Old 08-24-2012   #10
I believe Kurt White has a rescource on this for the rebuilds he is on here as LIMEY
Its a rebuild service with a quick turn around
http://www.whiteracingproducts.com/
I have used Kurt repeatedly for scarce parts.
