View Poll Results: Which oil filter do you use?
AC Delco 69 27.17%
Amsoil 1 0.39%
Baldwin 0 0%
Bosch 69 27.17%
Fram 13 5.12%
K&N 13 5.12%
Mobil 1 54 21.26%
Napa 12 4.72%
Penske 0 0%
Pennzoil 1 0.39%
PowerFlo 1 0.39%
ProLine 0 0%
Purolator 3 1.18%
Quaker State 0 0%
STP 0 0%
Wix 18 7.09%
Voters: 254. You may not vote on this poll
Old 11-28-2006   #11
BBBAD94ZR1
BBBAD94ZR1's Avatar
Default Re: Which oil filter do you use?
Jeff,
It was the new black ones, I purchased them around 2 months ago.
Ray
BBBAD94ZR1 is offline   Reply With Quote
Old 11-28-2006   #12
BBBAD94ZR1
BBBAD94ZR1's Avatar
Cool Re: Which oil filter do you use?
As Bosch being made by Champion I was unaware. I found a case of old filters from 4 years ago. My uncle owns a shop and had them in a warehouse. All I kwow is what I seen. When I had the filters that came with the car when I purchased it where old mobile ones painted black. The new ones seemed to be the issue.
Thanks for reading.
Ray
Old 11-28-2006   #13
Z Factor
Z Factor's Avatar
Originally Posted by BBBAD94ZR1
Thanks for reading.
Ray
That is what we are here for, to help each other out.
Old 12-01-2006   #14
I switched to the Bosch after I started having trouble with the new black M1 filters. I had been using the old grey ones & I had good readings on the gauge and very slight chain rattle upon cold start up. On warm or hot restarts there was almost no chain rattle.
My first oil change for the start of the summer the A/Z by me had the new black M1's so that's what I bought. Major chain rattle on cold start up, minor rattle on warm/hot restarts and an alarmingly long time to have O/Pres show up on the gauge. I was very concerned that my O/Pump was quitting on me. I bought another black M1 & tried it and had the same results....now I was scared!
Came home(here to our home) and looked around & read the newsletter at the netreg site and decided that I was having some bad luck with the new black M1's. I was going to order another O/P sending unit but buying a Bosch O/F was quicker. All I can say is using the Bosch instead of the black M1 my "noises" at cold start & warm/hot restarts are back to what they used to be when I was using the grey M1's. Quick rise of O/P @ start up on the gauge and very little chain rattle @ cold start. My 90 always had about 3 seconds of chain rattle at cold start as I doubt the original owner ever complained enough while under warr for the dealer to replace the right side guide? Anyway, it always had about 3 seconds of rattle after sitting a week. Warm &/or hot restarts had practically no rattle and the O/P gauge always showed a quick (you almost didn't notice a wait for O/P) build to operating oil pressure.
I guess the A/Z where I buy M1's got a bad batch??? The grey ones worked fine, it's the black ones I had bad luck with so now it's Bosch for my Z! I know that this is unscientific but the nosies & time to build O/P were giving me nightmares!
Old 12-27-2006   #15
Hib Halverson
Was using Mobile, actually purchased a case of them If anyone wants to buy them I'll sell them cheap.
Ray
How much you want for the case of filters?
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 12-27-2006   #16
bobbyhi
bobbyhi's Avatar
I have been using the Bosch and no chain rattle....
Hib - good to hear from you on the forum. Wish you were here more. You have a lot to contribute.
Old 01-07-2007   #17
90ZR1
wow... so many mobil 1's.... maybe ill try and switch, see if she feels better!
90ZR1 is offline   Reply With Quote
Old 01-07-2007   #18
Hib Halverson
Thank you, Bob.
I wish I could get here more often, too. I'm going to try better on that in 07.
Hib Halverson
Technical Writer
Old 01-07-2007   #19
DaveK
Has anyone ever tried the re-usable ones like the Pure Power one?
http://www.gopurepower.com/site/prod...lt.asp#FILTERS
Just curious - they look like a good idea 'on paper' at least and got a pretty good write up in 'Vette' a few months back.
Dave
1991 #1516 Black/Black
davidmkelly.com
Old 01-08-2007   #20
4DSZR1
4DSZR1's Avatar
I've been using the M1 and a couple months back I went with a Bosch. According to my highly claibrated ear, the Bosch may be a tiny bit better on cold startups after siting a week or so, some minumal rattle. Startups after just a few days are noticably better with no rattle at all.
4DSZR1 is offline   Reply With Quote
