Old 07-11-2012   #1
mgbrv8
Default Rock auto starters?
Are the Ac delco starters any good on Rock auto. They are $134
Dave
Old 07-12-2012   #2
batchman
Default Re: Rock auto starters?
I noticed they listed a thermostat housing for LT5 - checked an LT1 and ayup, same #.
You should probably check to make sure the starter they list is a different PN than an LT1...
Cheers,
- Jeff
Old 07-12-2012   #3
I just bought the contact kit on eBay and rebuilt mine.. all that goes bad typically is the contacts
Old 07-13-2012   #4
ghlkal
ghlkal's Avatar
Jeff, how difficult a job is the rebuild? (easier than getting to the starter, I hope )
Old 07-13-2012   #5
It is pretty straight forward.. it took about 30-45 min to fix the starter once I figured out how it comes apart
Old 07-13-2012   #6
VetteMed
You can search online for Denso starter rebuild instructions/pics.
The starter motor itself is very rugged, ball-bearing construction, seldom fails unless subjected to conditions outside design spec (i.e. water submersion, other causes of corrosion).
The need for rebuild comes from the copper contacts, and plunger, wearing thin.
