Old 06-27-2012   #11
scottfab
scottfab's Avatar
Default Re: ABS code 76 set
Originally Posted by 72ZR1 View Post
if the pendulum is sticking the computer doesn't now if your going around a corner or in a slide.it it thinks your always going straight.
No, I mean if you straighten it upright how do you know it's still broken?
Seems like all is well now. Your text leads one to believe the fix will not work.
Scott
Old 06-27-2012   #12
72ZR1
Seems like all is well now. Your text leads on to believe the fix will not work.
sorry what i meant was the light goes out but the sensor won't sens a slide concern.
72ZR1 is offline   Reply With Quote
Old 06-28-2012   #13
Don in VT
Hi All,
I bought a working used Accelerometer that matched the numbers from the failed unit in the car. Based on the tips from all of you I thought the used replacement would work. It did !!!!! I installed the new switch, erased the codes, took it for a test drive (at 3 mph the ABS motor cycled). Got no trouble code light. Check the ABS system by grounding pin 11 and I got 12, 12, 12. I believe I am good to go at this time.
I opened up the failed accelerometer and the weight moves but is binding up and not moving freely. I will play around with the unit and see if I can free it up.
Thanks for all the help.
Have a great summer
Cheers
Don
Don in VT is offline   Reply With Quote
Old 06-28-2012   #14
scottfab
scottfab's Avatar
I'd be curious to see any pics of the failed unit.
Where it's binding etc.
Scott
Old 06-28-2012   #15
Don in VT
Hi Scott,
I will take a couple of pix of the accelerometer and post them for you and others to see what the unit looks like with the cover off.
Thanks,
Don
