![]() Join Date: May 2007
There will be a Westminster Maintenance Day on Saturday, 9 June 2012 at the garage behind my house at 195 W Main St, Westminster, MD.
We will start at about 9:00 AM. Everyone is invited. Come out and welcome Rod Bailey from West Virginia. Come whenever you can, stay as long as you like. We will putting new injectors, coils, and plug wires in Rod's 1990. We will also be pulling a transmission to replace a noisy throwout bearing on Scott's car. If you have any questions, please call or contact me: Jim 443-244-1347 jim@gizmosart.com ![]()
If it isn't fun, you aren't doing it right! 1990 Black ZR-1 - sold 1993 Quasar Blue ZR-1 1994 Competition Yellow ZR-1 1995 Dark Purple ZR-1 Maryland State Coordinator WAZOO Member |
![]() Join Date: Aug 2011
I will be there at 9am. Can't wait to get my hands dirty! Any chance we will have time for a drive... maybe find the longest route to the ice cream shoppe? Can't wait to show you my Z now that it is finally 99% correct, professionally detailed, and running strong. i've doubled the 3,500 miles it accrued in 21 years in just 8 months - just hit 7,000 today.
The only ToDo's left are to change the trans to Castrol Synthetic and change the rear-end fluid.
Bert Rankin 1991 ZR1 Steel Blue / Steel Blue #1029 Haibeck chip, slotted rotors, camber brace, C-beam plates, OBX exhaust, Nitto NT555 tires [SIGPIC][/SIGPIC] |
I will be there!
Thanks ... Paul (Paul in VA) WAZOO Member |
![]() Join Date: Aug 2006
Oil change
Tranny fluid change Replace "K" member w/ boxed-in version Tighten up rear roll bar mounts w/ star washers (I think this is what makes clanking noise) Fabricate custom oil cooler lines I'll be there for SURE!!! Bert, You can take my car for a test drive. |
![]() Join Date: Mar 2012
I'll be there. Mine idles right now, and has no more left O2 lean issue.
My only current issue is the coolant getting too hot when not moving with the a/c on. I'm sure I just need to clean out under the radiator shroud.
91 Black ZR1 DRM Chip Corsa cat-back |
![]() Join Date: Jul 2008
Rats!! I'll be on a plane heading home from Lawton, OK next Saturday. I'll be with you guys in spirit. Take pics!
Ralph
robrtr '92 #225 Black/Gray WAZOO Member |
Bump
Weather looks great! Chance of rain is 0% (hope the weatherman/woman is right!!!) ![]() David |
Do you think with a Plenum Pull and a transmission pull, there will be time for me to change out my rear end fluid (21 years old) and transmission?
#10 |
Bert,
Jim say's yes. He can do it after Scott's flywhee/ T/O install. See you Saturday! ![]() David |
