Old 05-18-2012   #1
Tyler Townsley
Default Computer fans in inner fender.
Long ago and far away someone (AO Engineering?) made/had instructions to install 3 in 12v dc computer fans in the inner fenders Any body still have the instructions? Bought 2 tonight at radio shack to try. I would have gone with the 120mm units as some of them can get 150+ cmf but there is not enough room on the inner fender, the biggest looks to be 3in or 80mm.
'Tyler
Old 05-18-2012   #2
VetteMed
Default Re: Computer fans in inner fender.
forum member aafc has them underhood, I saw them a few months back. Might try to PM him. John's the name.
Old 05-19-2012   #3
Bob Eyres
I had some of Frank Yunes' (A.O. Eng.) promotional material for the fans. It came with the purchase of a "Forced Air" system. I can't seem to find it now. I think it was re-prints from "Corvette Fever", or "Vette" magazine.
If there's a way to search their archives, I'm sure there are some write-ups, and pix in there, if not a test.
If you've got a pile of those old mags around Tyler, start looking. But don't be like me and and try to read every article you come across
Old 05-31-2012   #4
aafc
aafc's Avatar
Tyler,
I had my car up on my lift the other day and checked the wiring for my a/o fans.The kit (two fans,instructions and wiring harness) is wired to the primary fan with a t-type plug. out of the plug there are 4 wires. two black and two red that go to the left front side of car. At that point they split into two groups one goes to the left side to the fan or fans, and
the other one goes to the right side to feed that fan or fans.
hope this helps
John Becker
1990 white/black #2546
one of a few auto(4l80E) eq zr-1's
Old 05-31-2012   #5
Tyler Townsley
Originally Posted by aafc View Post
Tyler,
hope this helps
John Becker
I went ahead and installed a thermostat setup with an adjustment so I can control the temps they come on and wired them direct so they pull the hot air out after turning the key off to prevent a heat soak. Currently have 2 fans installed and will end up with 6 (3 per side) in the end. You cannot hear them at all even when the key is off.
I have some pictures and will post them when done.
Tyler
Old 06-01-2012   #6
Gunny
Gunny's Avatar
Tyler ...
I'll be interested in seeing your pics once you get your setup going. Sounds like it might be a good "how to" write up. I know you're 4-5 hours south of me but you might have some cool ocean breeze occasionally ... when it gets hot in Georgia (I'm 100 miles from the coast) it's really HOT ... year round sometimes and our engine compartments need all the help we can get. Sounds like a mod waiting to happen once someone provides good pics and a write up ... hint, hint.
George
George Jones
Founding Member #14
www.zrwon.com
Gunny is offline   Reply With Quote
Old 06-05-2012   #7
Paul in VA
Hi:
I am very interested in your pictures as well! Can't wait to see them.
Paul in VA is offline   Reply With Quote
Old 06-06-2012   #8
Paul in VA
Do these fans take air from the engine compartment and blow it into the frnder/gill area?
Old 06-06-2012   #9
Tyler Townsley
No it blows into wheel well area,
Tyler
Old 06-07-2012   #10
rudolph schenker
rudolph schenker's Avatar
1994 ZR-1 Admiral blue/beige #67
rudolph schenker is offline   Reply With Quote
