Old 04-20-2012   #11
Default Re: high coolant temperature
Jano,
I agree with your observation from past years in that once the secondary fan does come on the coolant temp would drop enough to notice it on the gauge. I would look to see if the core has junk stuck in it. I also would think that if there was junk stuck in the core you would see the temps climb much faster than in previous years? I also would just check to make sure the secondary fan relay and the primary fan relay are both working correctly. Just to be sure I covered all the possibilities?
I hate to suggest pulling the shroud as that is a pain in the neck. Maybe you could look in thru the oil cooler side of the radiator or up thru the air intake opening at the front and get an indication if the car sucked up road junk into the core.
Old 04-20-2012   #12
janozr1
Thumbs up Re: high coolant temperature
NONONONO guys everything that you sad is ok jus termperature between engine coolant and radiator is too much different whan fans working , so I think that thermosta 180f becomes too lasy.I will change it and i will report
what hapenning . Bay the way , where is temp.sensor located ?
janozr1 is offline   Reply With Quote
Old 04-20-2012   #13
I think on the driver side injector housing. Follow the wires to it.
Old 04-20-2012   #14
Originally Posted by janozr1 View Post
ok , but still dont understand why temp stay there and doesnt dropp if both fans are running , usually were fans put temperature down and turn off for awhile...
because that's normal operating range.
Old 04-20-2012   #15
Coolant Temp Sensor Location Reference
Located on LH (Driver Side) Injector Housing, under the Plenum.
PN 12146312, 2 Pin (ECM) Coolant Temp Sensor
http://jerrysgaskets.com/store2/root...roducts_id=363
PN 25037346, Button Terminal (Guage) Coolant Temp Sensor
http://jerrysgaskets.com/store2/root...roducts_id=157
Thermostat
http://jerrysgaskets.com/store2/root...roducts_id=592
Old 04-20-2012   #16
janozr1
Thanks Jerry for info , first step will be replace thermostat it is easilly do that like change coolant sensor.
jano
Old 04-20-2012   #17
Ccmano
Ccmano's Avatar
Originally Posted by sammy View Post
have you pulled the radiator cover and see if the fins on your radiator are plugged . our cars are like a hoover vacuum cleaner . they gobble up every thing .plastic bags , leaves and small rodents .jk.i am willing to be that your radiator fins are partially plugged
Been there done that! This is your answer.... On first glance mine was clean, but on closer examination the fins of the radiator were plugged with fine sand. They all get this way after 20+ yrs. Had to replace the radiator. Might as well do the thermostat, hoses and belts while your in there. Like the old Fram commercial said "pay me now or pay me later"
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 05-05-2012   #18
janozr1
I changed thetmostat today and coolant temp. is going down , fans go
off like before if car is not moving and temperature between radiator and engine is not so different .....SO I HAD BAD THERMOSTAT .
On the left side is old one , on the right is new - got it from germanny
Which one is original , or better or what ?
thanks for help,
regards ,Jano
Old 05-05-2012   #19
The one on the left is the wrong thermostat.
Old 05-05-2012   #20
scottfab
scottfab's Avatar
thanks for help,
regards ,Jano
The one on the right looks like mine. Glad temps seem to be better. I would suggest doing what was poster before about inspecting and cleaning the front of the radiator stack. It's just good maintenance. I installed this screen 14yrs ago and it saves a lot of time. I inspect the screen and clean it twice a year.
http://www.zr1netregistry.com/ZR1_radiatorscreen.htm
Scott
