Old 03-09-2012   #1
Default foamy squares and upper cam wear strips X?
How many foam squares are on the underside of each cam cover? How many upper wear strips?
Is it one foam suare per cover and one end wear strip square. I dont have a cam cover in front of me so I honestly need the answer
Thanks for the help GC
Old 03-09-2012   #2
Default Re: foamy squares and upper cam wear strips X?
Yep ok thats is one foam square per cam cover and one wear strip on the front edge of the cam cover right? Any other plastics under the cam cover?
Old 03-09-2012   #3
I got the foam squares from Marc H. Used one per cam cover. Actually, I only replaced the pass. side. So far that appears to have been enough to reduce oil crankcase pressure. Obviously, if u are still in process of building motor, I would use one square for each cam cover. What "wear strip" are you describing?
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 03-09-2012   #4
The wear strip consists of two parts....a bracket with two small screws (use red loctite) and the wear strip clipped onto the bracket shown for the passenger side. You can actually see the wear strip through the oil filler hole with oil cap removed.
The square hole to the right between the wear strip and first spark plug hole fill with scotchbrite pads and hold in place with wire clip through the two small holes you can barely see top and bottom.
Ok thats what I needed to know I think I need to find another bracket. SO the wear strip slides into the bracket that is secured by the two screws?
Old 03-09-2012   #5
Thanks Dom I have 4 coming in the mail I just wanted to make sure I had enough for 4 cam covers.
Old 03-09-2012   #6
The wear strip has two clips one on each end and you just snap it on as it is flexible and the clips separate a bit when you snap it on. The two clips fit in the two slots of the wear strip on each end. Look on Jerry's webe site search for cam cover wear strip for a picture of the wear strip bracket and screws.
Thanks Cliff got it
Old 03-09-2012   #7
I will add a note in that 4th post that each engine only requires TWO Cam Covers
Coming soon the 64V 8 Cam Zr-1
Old 03-09-2012   #8
VetteMed
RPO LT10?
2004 Z06/Z16 LeMans Commemorative Edition
1991 ZR-1 #302 White/Gray (sold)
1991 ZR-1 #1147 Red/Saddle (sold)
Old 03-09-2012   #9
Default Re: Cam Cover Chain Wear Strips
fill with scotchbrite pads and hold in place with wire clip through the two small holes you can barely see top and bottom. Use Scotch Brite
Yessir. I did that. Then I read somewhere about some concern about the Scotch Brite residue getting into the motor.
I've not heard/seen any evidence of harm related to SB, so I'm not in a panic to pull my covers and replace them. But, if I had the covers off again for anything, anytime soon, I'll get a couple squares from Marc and that'll be that!
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 03-09-2012   #10
I used the Scotch Brite on mine. In fact, its still there on the driver's side.
I removed it from the passenger side cam cover because I thought it may have been dense enough to where it was causing the crankcase to pressurize at WOT. I saw a small puddle of oil at the bottom of one of the cam cover bolt bosses. The bolt is next to the vent tube. After having replaced the Scotch Brite w the foam, I have not seen the oil in that bolt boss again. I have no indication that the Scotch Brite has caused any other issue with the motor after ~3500 miles.
