Old 02-03-2012   #41
Default Re: Finally Heads are Done
Daryl
Congrats!!!!!!!
Long time coming. You will make us all envious!!!!!
Old 02-03-2012   #42
RHanselman
RHanselman's Avatar
Originally Posted by FU2 View Post
Stocker hold's good to 540-550 rwhp.
Frank,
My Stocker is holding around 620 rwhp! Of course the clutch isn't stock...
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1961 White with Red Int
Old 02-04-2012   #43
Corsa kills two birds ... DRONE & EXHAUST NOTE!! (Makes an LT5 SOUND like a Prius!)
JK...
P.
After having to deal with tinnitus like symptoms since Oct.. I will gladly use Corsa to eliminate the drone. The low pitched drone/ noises would really irritate my ears especially with the Tinnitus symptoms
I do like the sound of Pete's and the rest of the guys Exhaust systems, but due to my ear issues I have been having, I am not about to change it and regret the drone.. or risk having permanent damage to my ears..
Old 02-04-2012   #44
Polo-1
Ok fellers on the topic of Fidanza
Should I or Not?
Have listen. starts @23 second mark.
Old 02-04-2012   #45
Yep that is the dreaded rattle alright - just a soon as you let off the clutch it starts.
No doubt you have to just put a deaf ear to it all and just accept that it is what it is.
Now I see some of you have made it much better with the tune-new injectors and different tranny oil.
So I guess that you can make it better with a bit o work and fluid choice. This is good indeed.
How about a vid with good sound from one of you who have achieved this goal so we can have a listen to your tamed rattle beast.
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg
http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif
"The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC
" We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln
Old 02-04-2012   #46
I'll bet you look just like that!
Way to be Daryll! Use her in good health!
Old 02-04-2012   #47
I had the rattle on my 89 with the Fidanza flywheel and even being a blck tag it did not sound as loud as Polo-1's video. The rattle on my 89 was more subtle then that
Old 02-04-2012   #48
This is a vid of my ZR idling after ported heads and Pete intake cams installed. Near end of vid I place the camera on the plenum to illustrate vibration at idle.
I did quite a bit of additional tuning after this which is now incorporated in the tune I sent to GC. We'll see how it works. BTW, idle here is at 750-825rpm.
[IMG][/IMG]
Old 02-04-2012   #49
Polo-1
I should say that's a 402 with SCG stage 2 intakes and 1 exhuast cams. With a little cam the motor start to make the tranny rattle...
Old 02-04-2012   #50
[IMG][/IMG]Here's a video where you can here idle inside the cabin
