Old 01-31-2012   #1
oricale
Default UPDATE: Engine is pulled and secondaries gone!!
So as you know us here at WAZOO land pulled the heart out of my ride,...here is a few pics of before and now,...
the WHOLE car looked like this!!!,..
NOW:
SO,..the heads are @ C&C machine in Manassas,...
And I thought since I have ripped the entire system, down to the last screw of the secondaries..I would offer them to the highest bidder !!!
Anyway I am ordering a A$$ load of stuff from Haibeck and Jerrys as well as some other sources,...
Here's what were loading into the Z:
Headers
all new gaskets
Haibeck chip(when ready)for the secondary delete
Samco rubbers
new timing chains (primary and secondary)
all tensioners
Heads ported to 36mm
new exhaust
4:10's
ect(too much to list..
Anyway, I thought I would give a few Ideas on a few things:
Secondary butter flies and shafts removal:
uses the right torx bit, they will all come out with enough pressure( i used a electric drill. no problem,
The shafts I used a small flat head screwdriver and popped them out by layin the flat head against the inside of the shaft and used one medium hit with a hammer and they came right out!,...
I will be happy to lay out any information i can just let me know!...
oricale is offline   Reply With Quote
Old 02-01-2012   #2
VetteMed
Default Re: UPDATE: Engine is pulled and secondaries gone!!
Looks like fun!
Old 02-01-2012   #3
Only cow batman!!!!!!!
Now that's a project.
Old 02-01-2012   #4
Blue Flame Restorations
Always nice to see this type of thing. Keep the pics coming!!!!
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 02-01-2012   #5
Thats either a Black Widow wrinkle finish block or you had a massive amount of oil leaking.
Old 02-02-2012   #6
tccrab
tccrab's Avatar
Judging by the "After" picture, it was just oil and road grime.
TomC
'Crabs
Old 02-02-2012   #7
rhipsher
rhipsher's Avatar
If I had to go that far with my motor I'd seriously consider a 368 build or better.
Old 02-02-2012   #8
Corbusa
If I knew what they were worth or If I'd ever need them, I'd see what I could do..
It looks like you're having fun, wish I was there to help..
