No football today so spent some time in the shop.
Dicided I had enough with resetting chain tensioners the old fashion way using a small screwdriver, metal scribe, patients and a little luck. Made up these two little tools which make the job literally a snap. After fully compressing the tensioner on the drill press with a 1/4" rod chucked up the outer sleeve of the tool is pushed down on the inner plunger which sets the locking ring in the outer cylinder. ![]() ![]() ![]() ![]()
Phil neat tool mod. Will you be making more? Im in for a set. GC
![]() Join Date: Jul 2005
Very nice... Would love to have one...
Ron Hanselman Founding Member #80 CM Lifetime Member #1093 1991 #383 Twin Turbo 1993 #099 Ruby, Jeal 368 w/Snake Skinner body 1961 White with Red Int |
![]() Join Date: Dec 2003
Yeah, but I need that tool set more than both of you put together, so line forms to the rear. ;-)
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 01-29-2012 at 10:29 PM. |
![]() Join Date: Jan 2006
Only in the shower...... On the street, it's not a problem.
I made these up out of some scrap material I had laying around.
Next time I'm at the store I will pick up the right size round stock and turn out a few.
Phil,
Please ad me to the list. Ted |
#10 |
