Old 01-18-2012   #11
Scrrem
Scrrem's Avatar
Default Re: Spent the evening plugging the wife's....
OK Shek, you sold me. I think I'm doing this to mine before they go off for refinishing.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 01-19-2012   #12
Shrek
Rich
Good choice!!
Shrek is offline   Reply With Quote
Old 01-31-2012   #13
VetteMed
Are these 1/8" SS plugs sold at HD/Lowes, typically? Got the plenum off now, and I'd like to finally put an end to messing with the cooling system every time...
Andrew
Old 01-31-2012   #14
Scrrem
Scrrem's Avatar
Andrew
I was not able to find this thread on any plugs at local hardware stores here in VA, I endeded up ordering these from Summit Racing.
http://www.summitracing.com/parts/SUM-G1485R/
Rich
Ron Davis Radiator
Old 01-31-2012   #15
VetteMed
Thanks for the link, Rich!
Old 01-31-2012   #16
Shrek
Andrew
Not sure about the big box stores, but they are pretty common online.
We order often from McMaster Carr here at the shop and I just threw my order in with another job.
http://www.mcmaster.com/#stainless-steel-hex-socket-pipe-fitting-plugs/=g1o3x9
Rich
Those also look like a great option!
Old 01-31-2012   #17
VetteMed
OK, great. What is the correct size drill bit and tap to use?
Thanks!!
Old 01-31-2012   #18
Shrek
Thanks!!
"Q" (.332) Drill.......1/8-27 NPT Tap
Old 01-31-2012   #19
VetteMed
Thanks, Shrek!
Andrew
