Old 01-09-2012   #21
efnfast
Default Re: OBX cat-back exhaust
This sounds very promising to me. I'll do mine as soon as finances allow. Ceramic coating?????
Old 01-09-2012   #22
Originally Posted by Corbusa View Post
Thank You sir!, I'm going to see how quickly I can get started on mine.. I appreciate the info...
Please beware I can vouch for construction quality and reduction in back pressure. But the sound quality (whether you like it or not) is a subjective thing.
Old 01-09-2012   #23
MikeGolf
Not the exhaust system just the headers. The exhaust system is SS and doesn't need anything done to it.
'93 #166 Black Rose
[FONT=Tahoma][FONT=Arial][COLOR=red][I]“Out of every one hundred men, ten shouldn't even be there, eighty are just targets, nine are the real fighters, and we are lucky to have them, for they make the battle. Ah, but the one, one is a warrior, and he will bring the others back.” [/I]Heraclitus
[/COLOR][/FONT][/FONT]
MikeGolf is offline   Reply With Quote
Old 01-09-2012   #24
efnfast
Seems there has been a lot of discussion with pros and cons on coating headers. Do we the zroners like it and or recommend it?
Old 01-09-2012   #25
I recommend headers to be coated. I have seen stainless steel headers after a couple of years of use and they do turn grungy looking. If not for heat retention resulting in hp gain, at the very least do it for cosmetic reason. For $350, at least for me, it's a money well spent considering typical 2 person 6hr (total of about 12 hours) work for installation. I prefer not to do it over.
Old 01-09-2012   #26
Scrrem
Scrrem's Avatar
Well, here's a vote for coating...This is the way they will always look...
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 01-09-2012   #27
Coat them
Old 01-09-2012   #28
efnfast
Those headers are ceramic coated? Not what I expected. Thanks Scrrem, I think you just made up my mind.
Old 01-09-2012   #29
Scrrem
Scrrem's Avatar
Me too, not what I expected either from ceramic, once I saw them, I had to have it done. I had Jet-hot do mine, but I'm sure there are loads of companys out there.
http://www.jet-hot.com/
Rich
Ron Davis Radiator
Old 01-09-2012   #30
Ceramic coating......it really work's http://www.swaintech.com/
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
