Old 12-28-2011   #1
wrc95ZR1
Default Coolant Pipe is cracked=leaking, are these still available?
My passenger side Coolant pipe/tube (attached to the lower front plenum/intake) is cracked and leaking, slowly. Is this something that I can purchase new? Or do I need to find someone with an extra?
Thanks for the help!
wrc95ZR1 is offline   Reply With Quote
Old 12-28-2011   #2
Default Re: Coolant Pipe is cracked=leaking, are these still available?
Can it be welded?
Old 12-28-2011   #3
Scrrem
Scrrem's Avatar
Jerry has one.
http://jerrysgaskets.com/store2/root...roducts_id=356
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 12-28-2011   #4
I'm sure it could be welded. In fact, if you opt for a replacement, keep it or sell it. Depending on where the crack is, you might get by with JB Weld - at least till you can get it welded.
And, I have some aluminum brazing rods which might be just the ticket for a small job
like that. PM me and we can discuss it further.
P.
Old 12-28-2011   #5
wrc95ZR1
I was on his website earlier and must have missed it! I just bought the one Scrrem sent a link to along with a new gasket and set of bolts. Seems from reading on here that I will break at least one bolt if not all of them.
Im all over the JB Weld, just sanded down the PC around the crack. Should buy me some time until new part comes in.
Since these are rare and expensive I will have mine repaired and re-coated. I appreciate all the advice!
By the way, car only has 7K miles-why would this happen so soon? Age?
Old 12-28-2011   #6
Thanks for the order! You should receive on Saturday.
Scrrem: thank you for the referral an for posting the link. :-)
Old 12-28-2011   #7
sammy
could be from the car sitting dormant for so and may have been low on coolant creating a rusting situation .
Old 12-29-2011   #8
carter200
carter200's Avatar
Aluminum does not rust
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 12-29-2011   #9
It can be rewelded and Carter is correct it is aluminum. The cracking could be from everything to overtightening to overheating to a factory defect.
Old 12-29-2011   #10
ZR1Vette
ZR1Vette's Avatar
iron oxide= rust aluminum oxide= corrosion
Big difference is rust is expansive in nature (can open up seams thus can cause leaks in metal to metal contact areas) and will continue to erode the iron as H20 and 02 find new Fe molecules to combine with. With aluminum it is much more stable with H20 and 02, but will form a very thin layer of aluminum oxide which by definition is corrosion. For those who have had the SIR impact sensor to body chassis fault issue know of this effect.
See.. those chemistry classes did have an effect on me
