Old 12-21-2011   #1
Tyler Townsley
Default Flashing sys
I had always thought the flashing 'sys' was related to a battery dying. When mine started I pulled it and had it checked and it was ok. I cleaned all the grounds (including the fusable resistors) but still get the flashing 'sys'. Any other things to check.
Tyler
55 Polo White (Project)
61 Jewel Blue (Sold to buy above)
66 Nassau Blue
68 Torch Red
88 ZR1 Blue
90 ZR1 White
Old 12-21-2011   #2
mike100
Default Re: Flashing sys
I found out (when I rebuilt my steering column) that if the airbag fuse isn't in place, the sys comes up on the digital readout and the car won't start. I thought it was vats related...but anyways, just one other possible check.
Old 12-22-2011   #3
Hib Halverson
The IP flashes "SYS" when there are CCM codes set.
In the FSM, in the CCM section are instructions on how to get the IP to display CCM codes.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 12-22-2011   #4
You still might have an internal short in the battery under load. However a recent change to an Aftermarket Radio system can cause the same message.
Old 12-22-2011   #5
VetteMed
Typically the stereo issue is only a problem in the manual AC cars, since the automatic climate control LCD readout provides enough load in the circuit that the missing stock radio LCD doesn't upset the CCM.
2004 Z06/Z16 LeMans Commemorative Edition
1991 ZR-1 #302 White/Gray (sold)
1991 ZR-1 #1147 Red/Saddle (sold)
Old 12-22-2011   #6
Y-me
I've noticed that it comes on if someone took out a warning light in the info center, or the bulb burned out.
Y-me is offline   Reply With Quote
Old 12-22-2011   #7
Tyler Townsley
Bingo, I removed the bulb for the shock system since that bulb was always on. Guess I will have to put it back in to check.
Thanks
Tyler
66 Nassau Blue
68 Torch Red
88 ZR1 Blue
90 ZR1 White
Old 12-23-2011   #8
sammy
leave the bulb in and just break it .i did it to both my cars when i took out the tire inflation sensors off the wheels
