12-05-2011 | #11 |
Re: X-Brace
Man, that's awesome!!!
12-08-2011 | #12 |
Re: X-Brace
I have a new GM X-brace never installed yet. I was thinking of boxing it out also to make it stronger. What is the conventional wisdom? is it worth it? I only paid $100.00 for it. No! I'm not going to polish it!
12-08-2011 | #13 | |
Re: X-Brace
Best, - Jeff
12-08-2011 | #14 | |
Re: X-Brace
I get a lot of pros and cons on the R-D brace it works great for flex but loose some ground clearance. I have installed a 4 point roll bar and it really helped the back half of the car now the front takes the blunt of all the bumbs and too much movement this is why i wanted to know if the X-brace helps,i need to do something for the front end. I will let you know how well it works as soon as i try it. I would love to make my Z ride like a C5/6. The look of a C4 to me will never get outdated. Pete
12-08-2011 | #15 |
Re: X-Brace
does the "harness bar" or whatever they call it do anything or is it a waste? i'm talking about the one that mounts behind the seats and comes with a camera mount?
12-08-2011 | #16 |
Re: X-Brace
i love my harness bar
[B]"the winner ain't the one with the fastest car its the one who refuses to lose" - Dale Earnhardt :saluting: |
12-08-2011 | #17 |
Re: X-Brace
"The Jack Test"
Without the R-D brace, you can only pickup 2 wheels off the ground. The frame flexes too much to lift 3 wheels off. ( 94 ZR-1 with harness bar installed) With the R-D on, lifting the car at the jacking point it will pull 3 wheels off the ground. FYI My C6 Z06 pulls 3 wheels off the ground using jacking points. So, If I lift at the front ( under outside mirror ) 2 fronts and 1 rear are off the ground. The same thing happens at the rear lift point ( 2 rears and 1 front ). |
12-08-2011 | #18 |
Re: X-Brace
ran out of lift on my jack:
12-08-2011 | #19 | |
Re: X-Brace
Sounds like you need the RD Camber Brace not the Cross Frame. |
12-08-2011 | #20 |
Re: X-Brace
