Old 10-19-2011   #1
phrogs
phrogs's Avatar
Default Parting out 91 LT5
I have a 91 LT5 I am parting out.
This engine is apart I have most parts still but hit me up with what you need and We can see if I have it and see if we can agree on a price.
sold one camshaft need to verify what I have. I believe it was the LH exhaust.
Sold Left RH head
again let me know what you need and we can talk.
jp
quick inventory today
Used parts from a 30K motor that I intended on building but needed money and parted some of it so now its time to finish the job.
2 bolt block with lader $1000
oil pan $300
oil filter housing $300
LH cylinder head $900 drivers side
three camshafts $300 each
air horn $100
throttle body Sold
power steering pump $350
RH chain tensioner with housing compressed $400
LH chain tensioner with housing compressed $400
front engine cover $150
A/C compresor for 91-up $250
brand new secondary vacum pump the one from the truck $200
Coolant tubes $250
Pistons with conecting rods $100 each I have a a bunch
cylinder liners $100 each I have a bunch not from the above block
Spark plug wires MFG by Taylor used $40
spark plug wires LT5 sold
rear crankshaft seal housing $150
fuel pump assembly used $200
AIR parts group $300
Intake accordian Sold
crankshaft is iffy I remember it havind some surface corrosion on it so not sure if it would be worth using to anyone.
NEW PARTS
White Racing products Crankshaft bearing set $650
Camshaft timing chain wear strips or guide facing
I have Two of the cam cover guide facings
and three of the ones for the main chains $350 for all of them
JOHNNY P
Currently own
phrogs is online now   Reply With Quote
Old 10-19-2011   #2
limey
Default Re: Parting out 91 LT5
P&A
Ignition module
Ignition module interface board
primary timing chain sprocket
[SIZE=3][B][COLOR=Red]Worlds largest ZR-1 LT5 Parts Store[/COLOR][/B][/SIZE]
[URL="http://whiteracingproducts.com/"]http://whiteracingproducts.com[/URL]
New & Used Parts, as well as free Locator services.
[EMAIL="sales@whiteracingproducts.com"]sales@whiteracingproducts.com[/EMAIL]
(813) 264-6368
limey is offline   Reply With Quote
Old 10-19-2011   #3
ECM?
Old 10-20-2011   #4
Plenium and coolant pipes
Old 10-20-2011   #5
bobbyhi
bobbyhi's Avatar
Goldy, I have the coolant pipes off my '90 if you need a set.
Bob Anderson
1990 #2405 White/Gray
Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported
Minnesota State Director
Founding Member #19
Old 10-20-2011   #6
Torchred96
Plenum and IH...if Goldcyon passes.
thanks
sam
Sam
1991 ZR-1
:salute:
Torchred96 is offline   Reply With Quote
Old 10-20-2011   #7
phrogs
phrogs's Avatar
Originally Posted by limey View Post
P&A
Ignition module
I have one ignition module see them going for a lot of bucks.. one on ebay went for over $800 in the last two weeks.
interface board sold to you I think months ago.
Need to check on the timing chain sproket it might be in the block I need to pull the front cover off Ill let you know asap if I have it.
I do have an interface board but depends on how much you would give me for it since its from my spare motor.
JOHNNY P
Currently own
Old 10-20-2011   #8
phrogs
phrogs's Avatar
plenum sold!
See above for coolant tubes.
JOHNNY P
Currently own
Old 10-20-2011   #9
phrogs
phrogs's Avatar
thanks
sam
Sorry both are sold from this one.
JOHNNY P
Currently own
Old 10-20-2011   #10
phrogs
phrogs's Avatar
ECM?
PM'ed you
JOHNNY P
Currently own
