I picked up a few ZR1 parts a while back, in the box were a couple of parts I can't identify, can anyone help?
![]() This looks to be an oil pump driveshaft, but I didn't think LT5s had a normal shaft like this. Maybe a distributor drive? ![]() Obviously it is a pedal for either the clutch or brake, I just don't know which. Any ideas? I also got a rear brembo brake kit, anyone know who might have made it or any information on it? It has a parking brake included in the hub, so it definitely isn't a normal C4 kit. ![]() ![]() ![]() Thanks in advance! |
Looks like a custom kit allowing the parking brake to be retained however using Brembo calipers
![]() ![]() Join Date: Dec 2003
I agree with Daryll
Dennis Fierstein 90 ZR-1 #2562 Atomic-Z ZR-1 Net Registry Chairman of the Board ZR-1 Net Registry Treasurer |
Also for pre-90 MY cars prob 86-89. Not ZR-1 specific unless its a mule ZR-1 narrow body etc
#5 | |
![]() Join Date: Jul 2007
That pedal is a clutch pedal
Thanks guys, appreciate the help. Didn't realize there was a change in parking brake between years on C4s.
![]() Join Date: Jan 2009
I agree with Jeff on the parking brake setup. Not custom, just 88 and prior C4 setup.
The shaft is an oil pump drive shaft from a Chevy Pushrod V engine. Could be V-6 or small block V8 or big block V8. Jep |
Sorry, Make that 87 and prior. My Bad!!!
![]() Join Date: Feb 2006
The clutch pedal might be from a certain twin-turbo ZR-1 that was converted to an automatic. Just guessing.
#10 |
![]() Join Date: Jul 2005
There was also a non- turbo ZR-1 in your Indy area converted to Automatic.
