Old 08-10-2011   #1
Lightbulb winter projects A pillar replacement
This fall/winter I plan on replacing my A pillar weatherstripping again. Did this two years ago but the OEM replacement looks worse now than the original I replaced. Last time I did a how to do this with pics that I will do again so Cliff can capture the photos.
What else are you all doing this fall/winter? Any mods? GC
Old 08-10-2011   #2
digg101
Default Re: winter projects A pillar replacement
planning on replacing carpet,door panels and moldings on the 93 quazar blue. Marc Haibec has a set of heads and a plenum he is porting this summer. He will replace the stock ones on my 95 this winter. Also planning on installing C-5 brakes on the 95 this winter.
digg101 is offline   Reply With Quote
Old 08-10-2011   #3
Sounds like a lot of great projects.
Old 08-10-2011   #4
I have a set of H4 Lamps (bought off CF advertised as Hella, but are the Autopal brand) So I need to install those.
I also will replace my A pillar WS, I have then new piece already from Keen Parts (Latex)
Might swap out the exhaust resonator to see if I can change the sound a bit.
I had a Web Electric DRL in the car, but I had it mounted where in a spot that got wet, so I got a replacement and might reinstall that too.
If I get motivated I will change the way my aftermarket sound system is in the cargo area and add the X-over to make all the speaker have their own channel off the amps. Along with this I might swap in the 8s in place of my 6.5 in the back.
I think that is it
Old 08-10-2011   #5
What are you going to try? I have a Spare Corsa resonator if you just want to give it a try
I have ths mod too. I love it. I bet they would replace it for free if you ask. It is susposed to be mounted upside down. Mine is tucked in next to the nose
If I get motivated I will change the way my aftermarket sound system is in the cargo area and add the X-over to make all the speaker have their own channel off the amps. Along with this I might swap in the 8s in place of my 6.5 in the back. I think that is it
Im done in this mod area unless something bad happens lol
Old 08-10-2011   #6
I have Corsa, I like the no drone, but not the raspy sound.. I want to try a LT4 resonator (which I have)
I have this mod too. I love it. I bet they would replace it for free if you ask. It is susposed to be mounted upside down. Mine is tucked in next to the nose
Yeah I got it replaced Free of Charge.. Wire end needs to be pointing down, I had it next to the headlight Module, but it was sideways.. I will reinstall it but want to get a crimper and Weatherpak connectors for it.
Old 08-11-2011   #7
mike100
I might experiment with a turbo muffler on my Corsa pipes- maybe just paint them black to be like oem.
First I will probably renew my search for a standard targa lid in good condition since all I got with mine was the clear one.
Old 08-11-2011   #8
I'm considering
a gear for the differential - 409 Viper gear
and new Nittos
get a laptop and Tunerpro w/ appropriate interfaces and get up to speed on tuning these beasts...(I love Marc's chip, but it is a curiosity thing and I have a spare chip to play with.)
Weather stripping, maybe
new carpet on the doors and redoux the sill panel carpeting on the speakers (the "kit" didn't come with separate speaker covers - have to roll my own.)
If I get that done, that would be a lot (for me).
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 08-11-2011   #9
digg101
Paul,
What have you found for weatherstripping replacement?
Old 08-11-2011   #10
Paul,
not Paul, BUT
I have tried, Lonestar Weatherstripping (found on eBay), don't use it.. it is too hard
I currently have Melrose T-Top (their targa replacement pieces are great) the A and B they get from somewhere, while better, still not OEM soft
The Keen Parts A pillar I have feels like OEM, but I have yet to install
for the hatch I but an aftermarket piece from eBay works great
For the Doors I have OEM GM stuff
Hope that helps
