#11 | |
![]() Join Date: May 2010
#12 |
![]() Join Date: Aug 2006
I found an alternate product and will give it a try. Exterior install is what makes it tricky since header heat could negate the adhesive. I will keep an eye on it.
Eitherway, deletion of cats and jet coating, I believe, actually will reduce the amount of heat in the hump area. If I see these pads losing adhesion I will just yank the off. |
