Old 09-15-2006   #1
dlgeary
Default Help ! Oil in spark plug slot
I need some help from the experts!
I am a new owner of a 94 ZR1 (6 Months) and last night when I was changing spark plugs, the #5 cyl spark plug was covered with oil on the outside. I pulled the boot and oil dripped out of it and when I pulled the plug it was tight and looked the same at the other ones but with oil on the outside. All other plugs were fine.
The car has been running fine. I suspected the crank case vent that enters the plennem just above this plug, and checked the PCV valves but they were fine. There are no visible signs of oil.
Where do I start looking?
Don
dlgeary is offline   Reply With Quote
Old 09-15-2006   #2
Jeffvette
Default Re: Help ! Oil in spark plug slot
Don, has the engine been apart at all?
How high up the boot was the oil?
Old 09-15-2006   #3
dlgeary
I do not know if the engine has been apart, it only has 24k miles but had several previous owners.
The oil was about half way up the boot.
I have not started it since changing the plug but no more oil leaked into the slot while I had it apart.
Old 09-15-2006   #4
Jeffvette
I'm thinking the oil is comming from the seal inbetween the cam cover and the cylinder head. This is not a place oil usually gravitates to if it is leaking from someplace else.
Old 09-15-2006   #5
dlgeary
That's what I am afraid of too. Do you think that the first thing I need to do is take the plennum off to see what is going on in there. That is no small task in itself.
Old 09-15-2006   #6
Jeffvette
It's fairly simple to remove the plenum.
http://www.pnwzr1.net/LT5_tear_down.htm
I would suggest running the motor with out that psark plug plugged into the head and see if you have any seepage from the seal.
Old 09-16-2006   #7
Jim Jones
Jim Jones's Avatar
Location: I'm in a constant state of euphoria in the Z!
Actually with the help of Jeff's site, I took the plenum off without too much trouble. I printed off everything related to the LT5 teardown from his site and put it in a three-ring binder. It was VERY helpful, as I am a complete novice mechanic (that was my first major undertaking, and the car still runs!)
Good Luck!
Life's too short to be unhappy!
[IMG]http://i4.photobucket.com/albums/y128/koolaid117/Montage.gif[/IMG]
Jim Jones is offline   Reply With Quote
Old 09-16-2006   #8
Hotrod
FYI: There is an "O" ring seal between the the heads and the valve (cam) covers. When the seal goes bad, oil from the cams, works its way up around the spark plug (outside) and wets things down with oil.
Hotrod is offline   Reply With Quote
Old 09-16-2006   #9
dlgeary
OK, Thanks guys.
Jeff, these instructions are great. I will print them off and do some investigating. Looks like the only way to change spark plug wires is to take the plenum off anyways.
I have a full shop manual but sometimes those aren't descriptive enough.
Old 09-18-2006   #10
dlgeary
OK, you guys are NOT going to believe this but...
I had this idea to put some high temp Peratex Ultra Black sealant on the small lip inside the spark plug slot where the cam cover meets the head. There was a small lip because the cam cover was a little larger than the rest of the spark plug hole. I let it dry and cure for 24 hours then drove the car to our club picnic about 20 miles from home.
I checked it when I got home and no oil. I am sure this is a temporary fix but at least it works until I have time to take the plenum and cam cover off to fix it right.
Thanks again for your help. Jeff that website is awesome.
