Old 06-28-2011   #1
jrd1990zr1
jrd1990zr1's Avatar
Default Hydraulic Clutch Fluid
Noticed my clutch master reservoir is down a little, figured I would top it off.
I just got back from a couple auto supplys, a NAPA and a GM dealer.
Auto supplys don't know what I should use, GM dealer says GM fluid (12345347) is discontinued.
Any idea what should be used to top off?
Also any way to test the fluid in the system before I potentially contaminate it?? Not sure what previous owner might have used???
Any advice is appreciated.
Thanks, John
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 06-28-2011   #2
Default Re: Hydraulic Clutch Fluid
DOT 3 or Dot 4 if I recall
Old 06-28-2011   #3
ittlfly
I flush my clutch master cyl every year and refill with DOT 3. Appears to work just fine.
1994 ZR-1 # 0102...SOLD
ittlfly is offline   Reply With Quote
Old 06-28-2011   #4
To be clear DOT 3 brake fluid
Old 06-28-2011   #5
jrd1990zr1
jrd1990zr1's Avatar
Thanks Guys!!
Old 06-28-2011   #6
PhillipsLT5
PhillipsLT5's Avatar
but why is it low?
leaking slave?
Old 06-28-2011   #7
i've used dot 3 to top off before and the clutch started to chirp on me
Old 06-28-2011   #8
When I got the hydraulic fluid specifically for the the clutch hydraulic from a Chevy dealer I was told the fluid was not hydroscopic-meaning non-brake fluid.
Are we condemned to a substitute?
Old 06-28-2011   #9
Looks like summit has it, according to other sites its DOT3 with an addative; I have run DOT 3 with no issues
I think Summit has this in stock
Old 06-29-2011   #10
rhipsher
rhipsher's Avatar
Oh brother! Just get this stuff at Oreillys and be done with it.
