Old 06-01-2011   #11
jrd1990zr1
jrd1990zr1's Avatar
Default Re: ECM Code 61
Ted and Jim,
Thanks for the suggestion. I was looking at the vacuum diagram on page 6A2A-33 of the FSM and drivers side looks to be directly connected to the check valve. I just tried your suggestion and the pump continued to run. I took a snake light and looked under the plenum and found the main line into the tee had come out. I got the line into the tee using a pick-up tool and some long needle nose pliers. The pump now turns on and off about every 30 seconds to a minute, so I must still have a small leak under the plenum. I still will need to pull the plenum but at least now it may clear the code 61??? Need to get the car inspected this month.
Thanks again for the advice, John
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
