05-06-2011 | #1 |
Oil pump type?
Does anybody know if the pump is a gerotor or gear design, or have pictures of the inside of the oil pump? Just courious.
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT] [FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT] |
05-06-2011 | #2 |
Re: Oil pump type?
In the FSM the blow up picture shows a gear within a gear type. Isn't that a gerotor type pump vs the old fashioned meshed gear type in the old sbc motors?
05-06-2011 | #3 |
Re: Oil pump type?
Thanks for the info where to find it. I didn't see it in the supplement and didn't think to look in the big book. I think your right, looks like a gerotor.
05-07-2011 | #4 | |
Re: Oil pump type?
Here is photo of the inside of the pump when I rebuilt mine.
05-07-2011 | #5 |
Re: Oil pump type?
That's some flowand thanks for the picture, that must be part of the reason these lt5's are hard to break.
05-07-2011 | #6 |
Re: Oil pump type?
05-08-2011 | #7 |
Re: Oil pump type?
You're welcome. I think you are right about our oil pumps and not sure there has ever been a failure on one of these.
05-08-2011 | #8 | |
Re: Oil pump type?
Here is a post I did on a blog about the rebuild if it will help you. http://blogs.yahoo.co.jp/corvettezr1....html?m=lc&p=4 The page before towards the botton explains the carbon seal replacement and that is vital; thanks to Jerry for all his technical advice on this and recommending the new seal: http://blogs.yahoo.co.jp/corvettezr1....html?m=lc&p=3 To be honest, I think I was being very anal when rebuilding mine and I can't even imagine how these could fail other than the carbon seal side? I am sure I would have been fine, but since I was doing a rebuild it seem the right thing to do and hardly worn inside from visual inspection. Just old school and when rebuilding the SBC or BBC I used to always put in a new oil pump. Since I had a new OEM late model pump I just swapped the guts out to be able to sleep at night and hopefully with all the redline WOT the LT5 will stay together. Best wishes. Craig
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 Last edited by HAWAIIZR-1; 05-08-2011 at 05:50 AM. |
05-08-2011 | #9 |
Re: Oil pump type?
Craig, Thank you the links you did a great on the write up. I admired your patient and skill.
Shayne |
05-08-2011 | #10 | |
Re: Oil pump type?
