Old 04-30-2011   #1
KGV
KGV's Avatar
Default Location of blower control module
Hi,
The blower motor stays on in my ZR-1, and I read this is most likely a bad blower control module. I looked in the FSM, but I could not find its location. Where is this located, and is it easy to get to? What manual is it in?
Currently, I keep having to open the hood and use the batter disconnect switch.
Thanks
Ken
KGV is offline   Reply With Quote
Old 04-30-2011   #2
Default Re: Location of blower control module
Ken, I don't have my mechanical section of my FSM with me, but I just looked in the electrical manual and it says ... " RH side of bulkhead ( dash panel ), in LH side of evaporation housing."
The FSM calls it the Blower Power Module.
I figure that this thing is inside the heater box!?? and not on the engine bay side of the system? Does that sound like it makes sense?
Old 04-30-2011   #3
gbrtng
gbrtng's Avatar
Originally Posted by KGV View Post
Hi,
Thanks
Ken
Do you mean it stays on after turning the ignition off and removing the key?
Old 04-30-2011   #4
KGV
KGV's Avatar
Thanks, I will take a look in that area.
Yes, it runs all the time, even with the key out. I read on one forum that someones had the same issue with a late 80's C4, and they had to replace the control module.
Thanks for the replies. I thought that if it was an easy fix, I could get at it myself, but I may have to take it to the dealer here.
Ken
Old 04-30-2011   #5
gbrtng
gbrtng's Avatar
The blower module is on the top of the evaporator housing in the engine compartment on the passenger side. It's a 4-terminal device and looks to be common to all late C4s with automatic AC. I'd start there - the control module is inside the passenger compartment and would be the next component to suspect.
Can the blower speed be controlled by the AC controls in the dashboard? Does the blower continue to run at that speed when the ignition is off, or does it go to full speed?
Old 04-30-2011   #6
RICHARD TILL
had the same exact problem a while back and the module fixed my problem. i was lucky. found a module out of a 90 model in a junkyard for $20. theres no need to take car to a dealer. its a very simple job to change.
Old 05-01-2011   #7
KGV
KGV's Avatar
The blower motor runs at a constant speed. The fan control does not alter the speed.
Thanks,
Ken
Old 05-01-2011   #8
KGV
KGV's Avatar
Thanks. Do the wires just snap on to the module? Also, It it just two or three screws that hold it in place?
Thanks,
Ken
Old 05-01-2011   #9
RICHARD TILL
yes, the wires plug into the module. take the screws out and lift straight up.
