Old 04-29-2011   #11
Default Re: H.I.D. Headlights
Originally Posted by SDZR-1 View Post
i can take some pics of the exact factory lights and housing that I removed from my car. I just put them in our service truck at work since they were the same size. I have the housings installed in my car already and can place the xenon bulbs in there so you can see how they compare....but honestly they very bright. I do have the install instructions and boxes. All the connections with the kit are weatherpack connections and can only fit one way. You will need to use only one of your harnesses from the back of your factory bulbs...either side, but you only need one....the other can be tucked away or as i planned just remove the connectors from the harness so that it can be put back to normal if ever desired. You will also need to run one of wires to the battery for power. If desired, i will label everything...but it's pretty straight forward for someone with at least a little 12 volt experience.
Oh...i bought it from KT Auto online. I'm sure if you do a search you would be able to find the kit like mine.
I'll try to get pics at noon today and post them as soon as i can.
Thanks!
60 shipped? I'll give em a try
Old 04-29-2011   #12
SDZR-1
pm'd ya.
oh, and they are glass housings.
SDZR-1 is offline   Reply With Quote
Old 04-29-2011   #13
TFENT
I did this upgrade on both the headlights and the fog lights. I LOVE it. Super bright! I used the Hella Glass housing. Had my stereo guys do the install. Don't recall the total cost but TOTALLY worth it at any cost.
MovIt Brakes USA
[url]www.TFEnt.com[/url]
TFENT is offline   Reply With Quote
Old 04-29-2011   #14
Jarvis paypal sent. GC
Old 04-29-2011   #15
Originally Posted by DaveK View Post
Welcome
I'm interested in upgrading my lights also - been looking at the offerings on corvettehid.com but I think someone here had problems with their stuff so I'm not sure whether they are a good source or not.
(think it might have been goldcylon that mentioned issues with them in fact)
I had issues with the Corvette HID Foglight kit. For all I know the problem was a bad ballast. I just gave up and sent it back in the end and they refunded my money.
Old 04-29-2011   #16
Yeah I have the Hella housings as well so I will try those out first.
Old 04-29-2011   #17
wouldn't going to HID fog lights sorta defeat the purpose of having fog lights?
Old 04-29-2011   #18
PhillipsLT5
PhillipsLT5's Avatar
need to change wiring/fuses ?
Old 04-29-2011   #19
Dont think so
Old 04-29-2011   #20
SDZR-1
nope...there is an inline fuse on the power wire to the battery
