I bought a set of hid h4 style headlight bulbs, ballasts, harness, and new projector style headlight housings. this is everything you would need to install in your car. I did have to lengthen the wires on the bulbs so that it could pass through the rotating hinge of the headlights. I have that much done, but could use a little extra cash. I paid $117 for them and will let them go for $60 obo. I have tested them and they are 100% functional and very bright. The picture shows everything that is included in the kit, plus the extension wires that I have installed to make them work with our headlight system.
#2 | |
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 04-29-2011 at 10:46 AM. |
i can take some pics of the exact factory lights and housing that I removed from my car. I just put them in our service truck at work since they were the same size. I have the housings installed in my car already and can place the xenon bulbs in there so you can see how they compare....but honestly they very bright. I do have the install instructions and boxes. All the connections with the kit are weatherpack connections and can only fit one way. You will need to use only one of your harnesses from the back of your factory bulbs...either side, but you only need one....the other can be tucked away or as i planned just remove the connectors from the harness so that it can be put back to normal if ever desired. You will also need to run one of wires to the battery for power. If desired, i will label everything...but it's pretty straight forward for someone with at least a little 12 volt experience.
Oh...i bought it from KT Auto online. I'm sure if you do a search you would be able to find the kit like mine. I'll try to get pics at noon today and post them as soon as i can. Thanks! |
![]() Join Date: Jul 2004
1991 #1516 Black/Black davidmkelly.com Author of fast-paced, sci-fi thrillers. |
i believe you are correct...i didnt buy them directly from there, but the harnesses and components in those pics look the same. thanks for searcheing!
Welcome
![]() I'm interested in upgrading my lights also - been looking at the offerings on corvettehid.com but I think someone here had problems with their stuff so I'm not sure whether they are a good source or not. (think it might have been goldcylon that mentioned issues with them in fact)
#10 |
![]() Join Date: Jul 2007
are the housings Glass or plastic?
put me in line as well
