Old 04-21-2011   #31
Polo-1
Default Re: Siamesed and dropped plenum on the bay
Originally Posted by USAFPILOT View Post
So what would be needed in addition to that stuff to have a complete engine? How much of my stock 94LT5 could be used?
what do you want to build.
The block is 4.00 bore Im sure .010 to clean it up. If use your stock 350 crank (offset ground) 3.75 you would have 380ci. on the stock rods. need new pistons. use your cams,oil pump,pan,chains,front cover, damper,flywheel, chains,.... all the little bits from the 350.
just a start.... or go $5k for crank and jump up to 400+ci.
Old 04-21-2011   #32
USAFPILOT
USAFPILOT's Avatar
I always thought I would eventually do one of those offset grind builds one day. They seem to be the most economical, but any rebuild is out of my reach at the moment. For now a stock 350 headers and tune is about all I can afford. It is very tempting though. The AF doesn't pay me enough to do what I want with this car yet.
Old 04-25-2011   #33
HADI-ZR1
Originally Posted by limey View Post
What else do i have to do to sweeten the deal to get this lot sold.
Fully ported heads with large valves - big *** dropped plenum "415" block with studded mains, full set of bearings and gaskets, as well as a full set of new head bolts & 32 new lifters!
$8.5k & i'll cover the shipping US only though.
Hi Kurt...
can you please tell me why you not contact me and reply me regarding my order??
I wait your email. Long time no answer!! Give me little bit of your time.please!!
Hadi
HADI-ZR1 is offline   Reply With Quote
Old 04-25-2011   #34
USAFPILOT
USAFPILOT's Avatar
so is that 415 block you are throwing in good, or is it the block that was messed up during the build from BK?
Old 04-25-2011   #35
rhipsher
rhipsher's Avatar
If it was me I'd be in prison for murder.
Old 04-26-2011   #36
limey
The block is fine, there was no damage to it, it spun a bearing but didn't take out any part of the block.
limey is offline   Reply With Quote
Old 05-02-2011   #37
limey
SOLD!
