04-04-2011 | #1 |
LT5 DIY Rebuild Cost??????
If you were to rebuild an LT5 yourself, how much just for parts?
368 530hp and 415 650hp
1988 KOH Prototype EX5023 sold 1990 ZR-1 #444 Convertible 1990 ZR-1 Black #966 1991 ZR-1 Quazar Blue #296 1957 Duntov SS Project Last edited by Blue Flame Restorations; 04-04-2011 at 09:50 PM. |
04-04-2011 | #2 |
Re: LT5 DIY Rebuild Cost??????
way to many options to say a single price.
My 402 ( now Jim's) HD liners, ARP studs, Cams, Mono runner intake, optioned out JE pistons, Moldex Crank, Crower Rods, Block work on Rottler CNC.. and a few more things. over $30k without putting it together. A base stroker ( any crank ) $20k plus. Budget 379-383ci ( stock crank offset ground) add $300 over a 368. Should be able to do a 368 under $10k. Want cams... $3800 plus Last edited by Polo-1; 04-04-2011 at 10:40 PM. |
04-05-2011 | #3 |
I can provide gaskets, seals, cam sprocket bolts, rod bearings, main bearings and Permabond A136. Also valves, springs & lifters if needed.
As stated previously, there are a lot of options. You can use the stock rods on a 368, as-is or modified & lightened. You can shop my website & get prices on what ever you want.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 04-05-2011 at 12:31 AM. |
04-05-2011 | #4 |
Thanks, everyone. I appreciate the input.
04-05-2011 | #5 |
What is the cost to convert a block to 415 configuration?
Sleeves cost?
1988 KOH Prototype EX5023 sold 1990 ZR-1 #444 Convertible 1990 ZR-1 Black #966 1991 ZR-1 Quazar Blue #296 1957 Duntov SS Project Last edited by Blue Flame Restorations; 04-05-2011 at 04:55 PM. |
04-05-2011 | #6 |
any 368-415 the same liner LA # LT5 $1100-1200. 4" bore drop in replacement liner.
Then hone to fit piston,range $250-1000. Rottler CNC work I spent a $1000. Boring bar guys with hone plate $250-400. Ron Woods had made a LA sleeve HD version of the LA#LT5 liner. The block has to be honed (bored) about 0.030 over to press fit the HD liner. I was thinking they are $1200-1300 something like that. http://www.zr1products.com/#!related-vendors 396,401,427,441 built from 4.100-.125 bore. This is money. the block work for this is major and prices were from $6000-$12000 for liners and block work. Fitting the rod throws to the block, very little work. ( 1 hr labor). bottom line for bare block with 4" bore $2000-2600 range will get it done. I had a block with liners finished to 4.010 on the Rottler CNC and it did not sell for $1500......... I finally sold it to GC and in the middle of making it a 380ci budget mini stroker. Only build a LT5 out of the love for it. Other wise build a LS motor MUCH cheaper. |
04-05-2011 | #7 |
LPE will build you a 415 for 29K. No idea what parts they use etc. but you also get a 2 year warranty.
04-05-2011 | #8 | |
that would be awesome but I'm not looking to spend that much at all. Too pricey for me. I'll probably just do a top end P/P, headers, 410's, exhaust, chip and run the hell out of it. A 368 or 380 sounds feasible as well. If I'm going to spend another $29k, I think I'd just buy a C6 Z06 and have my ZR1's and 53 to accompany it.
